The fan in my compressor is not turning while my furnace is running, extreamly cold outside
    Scholar:
  • 185 Answers
If you are reffering to a heat pump.
That is by design.
the fan on the compressor like those in modern automibiles are thermstatically controlled.
It is an energysaving strategy.
They only work when necessary. If it is very cold outside, the compresor does not get warm enough to need fan cooling.
Since the air around it is enough to do so efficiently.
it is working fine and saving you on you energy bills too.
Posted on Jan 30, 2010
Auto/On set to ON. Fan runs.
Sounds like the thermostat, the way to verify is to unplug indoor unit, remove thermostat, take pic of wiring with phone or label the wires as to the terminals. Carefully twist the yellow,(Y) Red (R) and the green (G) together. Plug the furnace back in, if the unit operates normally, replace the thermostat. I am basing this on the fact that the blower speed is changing. This could also be an anomaly within the circuit board in the furnace section, not likely though as the outside unit (condenser) is not controlled n by the indoor board unless this is a heat pump. hope this helps. D
Jul 21, 2015 | Dometic Rooftop RV Air Conditioner
Unit not blowing cold air. Outside compressor and fan not running. Outside computer board has flashing red light.
Onboard diagnostic indicates 24VAC is still being supplied from the furnace.....should be a code on the inner cover or available online. Start with 220V service to the condensing unit once the diagnostic is resolved.
Jun 02, 2014 | Ruud Central System Air Conditioner
The furnace is running but there is no cool air. I change my filters every month and I flushed out the water lines last month.
flushing out water lines do you mean condensate line coming off the furnace that drain to the outside. is the condensing unit outside running when u have it in cooling mode. by condensing unit I mean the unit outside that has lines that run to the inside. does that turn on when u have it in cooling. the unit outside have two components that should turn on the outdoor condenser fan and a compressor.
Aug 21, 2011 | Ruud UAKA060 Air Conditioner
I have a Haier air conditioner model HWR10XC6. It's been in storage since last fall, and I put it in our window this morning. I plugged it in, and the light on the panel came on for a split second,...
First check if the fan is running. If the fan is notrunning is the compressor not running also, if neither is running the possiblereasons are 1, no power to outside unit, 2.bad contactor on outside unit, isthis buzzing if it is this indicates no power, 3 bad capacitor, do bothcompressor and fan humm then quit humming and hum some more, 4 high pressure switchhas shut unit down because fan wasn't running if compressor was running but notfan, if your unit has this there will be a manual reset button where the lines come out ofunit. If compressor was running and fan was not, 1 bad fan or 2 bad capacitor. Please check these followings: 1. Thermostat checks i) Is thesystem selector switch in the "Cool" position?
ii) Is the temperature set at least 3 degrees below current room temperature?
iii) If your thermostat is electronic, are the batteries charged?
iv) Some forced-air furnaces have a switch on the thermostat that allows you toturn the fan on independently of the furnace or air conditioner. This switchwill be marked "ON" and "AUTO". Does your thermostat havesuch a switch?
v) If the answer to the above is Yes, listen for the furnace fan coming on. Ifyou cannot hear the fan, go to one of the supply registers and see if you canfeel any air coming up. Is the furnace fan operating?
If everything seemsfine with the thermostat, the next step is to make sure there is power going tothe furnace.
2. Electrical checks
(A) Items to check at the furnace
i) Your systemmay be equipped with an emergency shut-off switch for the furnace. If so, makesure it is turned ON. In most homes, the emergency shut-off switch looks justlike a regular light switch and will be located close to the furnace. (Tracethe wire from the switch to the furnace to make sure you have the right switch.)It is quite common for this switch to be turned off accidentally. If the switchis ON, but the fan still doesn't operate, proceed to the Items to check at theelectrical panel.
ii) Some heating systems also have emergency cut-out switches that are activatedwhen a door or service panel is removed. Often the furnace door is not replacedproperly after a filter cleaning and the cut-out switch will prevent thefurnace from coming on. Check to make sure all access doors are properlysecured and fitted. (B) Items tocheck at the electrical panel i) Thebreakers for the air conditioner and the furnace should be in the"ON" position. If a breaker has been tripped, it will be in aposition between ON and OFF. To reset, turn the breaker all the way off and thenback on. If you have fuses instead, make sure the fuse hasn't blown. If it has,replace it with the same-d fuse. If you havedetermined that there is power to the furnace but you are still not getting anyheat, select your heating fuel type from the list below and continue with thechecks. If you have discovered that the furnace is not getting any power, callyour service contractor. (C) Items tocheck at the air conditioner i) Somecentral air conditioners are installed with a switch, or electrical disconnect,mounted outside to turn off the main power to the unit. Whether or not you havesuch a switch will depend on the electrical code in your area. If you have adisconnect switch, check to make sure it is in the ON position.
ii) Is the fan running on the unit outside? (If the fan is running, you havepower to the unit.)
iii) Some air conditioners will make a little buzzing sound, even when they arenot running. Have you ever noticed this before? Can you hear it now? Summary: Ifyou have determined that there is power to both the furnace and air conditionerbut you are still not getting any cool air, continue with the checks in thisguide. If either the furnace or air conditioner does not have power, call yourservice contractor. (D) Icechecks i) Is thereice building up on the pipes connecting the furnace to the air conditioningunit outside?
ii)Touch the plenum (this is the sheet metal box that comes off of the furnace;the evaporator coil is inside). Does it feel very cold? If it does, theevaporator coil may be frozen and you'll need to call for service Hope this will help you. Good Luck.
Jul 15, 2011 | Haier hwr10xc6 Air Conditioner
My air conditioner will not Start on it's own. Then temp controller in house makes a click sound, the furnace fan then runs like it should. But when I go outside I hear a buzz and click sound like it's...
compressor locked up. try hitting top of compressor with a block of wood on top and a hammer, wait a few min. then turn on. if it dosen' start u will have to replace it.
Aug 06, 2010 | Heating & Cooling
Heat pump and gas furnace running at the same time.
An explanation....
When in the heating mode, all heat pumps are dependent upon the outdoor conditions to remove heat energy from the environment and turn it into useful heat for your dwelling.
Heat pumps operate more effectively in temperate climates (as in southern states) and if it's as cold as you say, then the furnace is coming on to add auxiliary heat to the space to make up for the lack of heat being supplied by the heat pump. This is normal.
Some heat pump systems are or can be equipped with a control known as a "low ambient cut out" and/or "motor master" that prevents the heat pump compressor from operating and slows or stops the condensing unit fan when it's too cold and risking potential compressor damage. When it's in the single digits outside, a heat pump is only marginally effective. and usually requires auxiliary heat (your furnace).
If the furnace keeps operating when it's in the 30s or 40s, you may want to have the system examined by a competent service technician. As always, the outdoor condensing unit should be kept clean and the furnace filter should be changed no less than monthly, unless you have an electronic air filter.
Jan 07, 2010 | Heating & Cooling
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Ruud heat pump outside fan won't run
Tell him to make tight connections.
Jun 23, 2009 | Ruud UBHC Air Conditioner
Blower will not turn on when a/c compressor comes on - tstat ok fuses ok
You should have a fan relay on your furnace that would control your fan in air conditioning and that sounds like you are needing
May 24, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
