Question about Vacuums
I have a Hoover Mach 3 Cyclonic bagless upright vacuum. It works for a room or two and then it just shuts off. Then it won't turn back on for hours. Any suggestions on how to make it stop doing this? The canister is cleaned out.
    Problem Solver:
  • 16 Answers
This vacuum is very picky about air flow clean the filters and that should do it
Posted on Feb 03, 2010
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
Hoover Platinum Cyclonic Bagless Upright Vacuum, UH70015 squealing sound
have you checked the belt for the brushbar it may av stretched and needs replaceing here is the manual on link below
http://hoover.com/file/556/
Feb 16, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
It is a Hoover mach 5 runs a few minutes then shuts off no power laglass@sbcglobal.net
This sounds like a thermal limiter issue, usually caused by restricted air flow. Investigate until you find a blockage.
Dec 12, 2010 | Hoover U8145-900 Savvy Bagless Upright...
Mach 6 shuts off
If the vac shuts off and then turns back on after waiting a while. could be a thermal fuse. it is in the motor compartment. recommend a pro shop service this issue.
Sep 27, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoove Cyclonic Bagless vacuum shuts off after only a few minutes
The motor has a protective overload cutout device to stop it from over heating - this can be caused by a blockage of some sort in the hose or brushroll compartment or blocked filters.
After checking the above and it still cuts out, take it back under gurantee
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Vacume is a mach 4 cyclonic, it runs for about 8 minutes and then it shuts itself off? any idea?
The only thing I can think of from your additional comments is when it warms up something expands and it loses continuity of the circuit. Most likely the switch or the breaker.
Another thing to check is if it has a hepa filter it may be clogged and is tripping the circuit. Try this. Remove the hepa filter, turn it on and let it run without vacuuming anything. If it continues to run past 10-12 minutes get a new filter.
May 09, 2009 | Hoover U8145-900 Savvy Bagless Upright...
My hoover mach 5 stopped during use and will now not turn on
If the machine overheats, a breaker trips. Most breakers reset themselves after they cool off. You may have a manual reset button to push on your model. The machine will overheat if the bag is too full, or if the exhaust port is clogged. The reset switch is usually on the back of the motor housing, near the footswitch.
Dec 22, 2008 | Hoover Commercial C1660-900 Bagless...
How to fix wheels on hoover vaccum cleaner
i cant get the back wheels off my mach 3 hoover vacuum can anyone help?
Jul 14, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Vacuums Logo
184 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
