Question about Nintendo Wii Console
Even aftet cleaning lens still will not read disc
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 62 Answers
Your wii might need a new laser.
Posted on Feb 01, 2010
I have LG DH4220S home cinema, at firstli he was read my discs and now he does not reading my disc and write "disc err" and open the slot/
DVD drives do from time to time get dirt or dust on the lens. This causes the disc not to read and is rejected. It's very easy to get the lens cleaned. Hi-Fi and electrical shops will sell you a product that will clean the lens. I have even seen them in Poundland or cheap stores. That should solve the problem. If it just one disc, then you will need to clean the disc. But if there is a nasty scratch, the disc will never play. It is possible to get the disc restored and some companies offer this service.
Jan 13, 2016 | LG Audio Players & Recorders
I have a philips wireless music center wacs700 when i put disc s in even a lens cleaner disc it comes up cant read disc can you tell me what the problem is
lens cleaner not alway working.use air to blow unit out,,lots of dust inside of units...try to clean lazer with earbud very softly untill it shines,90% its works if not u need to replace lazer and hope its not the mpeg board...im a technician
Mar 28, 2012 | Philips Audio Players & Recorders
Do I need a dvd cleaner and what kind
Hello
DVD cleaner is a kind of CD, which will have cleaning pads sticked on it. When we insert the disc in any disc player, this cleaning pad will come in contact with the lens of the reading head. As the cleaning CD spins at hing speed inside the disc player, it will wipe out all the dirt and dust, if accumulated on the lens. Thus cleaning of laser pickup lens occurs.
This cleaning disc can be boutght from most of the electronic spare part shops at your town. Even after using this disc, your DVD player does not reads any disc, its laser pickup assembly is faulty, and should be replaced. OK.
Nov 19, 2011 | Televison & Video
DVD player will not recognize any DVDs I put into player. I even took top off and cleaned laser eye and still does not play. Now red light is on in place of green power light. What's up with this thing?...
No disc error can be a DIY like the following steps.
Assuming that the disc is good.
Since you've already done the #1 now proceed to #2.
1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Good motor - reading should be fairly high and it will spin.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I
Jan 24, 2011 | Oritron DVD600 DVD Player
"No Disc" error
try a few things first, the issue is that the disk decoder cannot get the information of the cd lan surface this is due to either a bad laser unit, or a very direct lens. cleaning is simple but if the disk cleaner didn't work you'll have to open the unit and wipe down the lens with alchohal esd safe, get at electronics store. sometimes their are stickt subtsances that get on cd discks and are transfered to the lens when it is reading cause the close proximity to the surface at high rpm's good luck.
Dec 21, 2009 | Zenith XBR716
Disc read error
Disc Read Error is mainly due to worn-out,dirty lens and it can also appear because of the disc that you have inserted in your PS2......
Try following to get rid of DISC READ ERROR:
  • Clean your PS2 lens:
Watch this video first
This will help you in cleaning the lens.You can also clean your PS2 lens by some lens cleaning DISC.Make sure not to touch lens with your hand.
  • Clean your DISC:
Watch this one to clean your DISC
Thank you!!!
Nov 12, 2009 | Sony PS2 Dual Shock 2 Controller...
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
Toshiba D-VR4 DVD recorder/VCR player
you can get the cleaning disc at any electronic store or even at some other stores like drug stores and even at the dollar store , but if the laser lens is probably to dirty to even see that disc if your player will not even read a music disc, have you tried a music disc? can it read it ? if so the cleaning disc will work.
if not then taking the player apart and manually cleaning the lens will be required
Dec 29, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Cd player
RCA has had lots of bad laser pickups the past several years. It has to focus before it will spin. Sometimes they will focus and spin but still not read the disc. Unfortunatly that unit is a throw away and no parts or service literature is available from RCA/Thomson. So if cleaning it does not do it, you are probably out of luck. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 16, 2005 | RCA RS2505 CD Shelf System
Nintendo Wii Console Logo
90 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
