I have a atrix 9001 and i am trying to install the lcd fan controller, i have the leads to plug into the fans but where the hell do i plug them in!?
2 Suggested Answers
dekinstoke
  • 96 Answers
SOURCE: Atrix 9006-C4 Black Midi Case 520W fitting for lcd display
There will be "headers" on the motherboard for some case fans. Look for 2/3 pin connections on the board marked "sysfn" or something similar. Any other fans you will have to fit to a spare Molex power connector from the power supply ... you can buy 2 or 3 way "splitter" cables to give you more power connections from one Molex for this purpose. BTW make sure you connect the cpu fan to the "cpu fn" header !!!!! That one is rather important :-P
Posted on Dec 31, 2008
04 nissan maxima radio and lcd screen not working ac still works radio comes on when I start the car then shuts off was told itz not a fuse what could it be and how can I check it
04 nissan maxima radio and lcd screen not working but ac ...
www.fixya.com/.../t25874114-04_nissan_maxima_radio_lcd_screen_not
5 hours ago - Run a 12 volt jumper lead to the fan motor connector from the battery or fuse box, if the fan runs replace the fan speed control module.
Sep 21, 2015 | Nissan Cars & Trucks
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
My motorola atrix 2 wont turn on
try pressing power key + home key + volume up key at the same time, see if you can boot to recovery, then, once rebooted, select clear cache partition, then select wipe data/factory reset..
and better not use a charger not compatible to your phone.. hence it would burn those leads inside..
Dec 29, 2012 | Motorola Mobility Atrix 2 - 8gb - Black...
Light only turns on with the remote. How do I set it to turn on with the wall switch?
There are some fan models (particularly with a remote control) that use multiple cycles of a single power switch to select the operating mode. For example, if you simply flip the switch on, you get the fan. If you flip it on, then off, then on again within one second, you get the light. If you flip the switch on - off - on - off - on, you get both. The trick is to do it fast enough so the internal power circuit doesn't run out of capacitor charge and forget what you're trying to get it to do.
Sep 28, 2011 | Hunter 52" Ceiling Fan With Light And...
Dec 20, 2008 | Atrix (CSCI-C8001-C43) ATX Mid-Tower Case
Replace 120 mm case fan
Quite simple, unplug the power lead from the power supply or motherboard. Then you will need to unscrew 4 screws that hold the fan in place. Install a new fan. Screw it into place like the previous one was and plug in the power lead.
Jul 07, 2008 | Gateway Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
