Question about Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro
How to wire timer for 208 lighting - Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro
    President:
  • 2,992 Answers
The Model T103 is designed for 120VAC. You might just want to purchase a T104 which is already made for 208V use. That would be the simplest and safest solution.
If your incoming power is 120V/208V 3-phase with a neutral, you could try rewiring the timer. Disconnect the timer motor from the contact screws and wire it directly to one phase and the neutral.Then use the two switch poles to control the 208V line wiring. If you have no neutral available you're out of luck. You should probably consult a licensed electrician to avoid any insurance liability.
This site has the 208V timer as well as downloadable instruction sheets for the 100 series.
Posted on Jan 31, 2010
Wiring a dimmer switch with 208vac, single pole
208 Volt 2-wire is generally achieved by pulling two hot wires off 3-phase 120/208 Wye or 208 Delta, or Highleg to center tap off high leg delta.
http://waterheatertimer.org/How-to-wire-3-phase-electric.html
http://waterheatertimer.org/images/3-phase-timer-diagram3-T104-208-240.jpg
Since each of these three phase systems also offers 120volt for lights, and a dimmer can be used for lights, then I wonder what you are using dimmer for?
208 volts.can be controlled by turning off one hot of the two hot wires.
Install dimmer on one of the hot wires, and see what happens.
Is the dimmer rated for 208 volts?
Add a comment and say what you discover.
Jan 03, 2013 | Generac HTSN400G 400Amp HTS 3ph 120/208V...
The power is working, but the yellow timer does not move. It's a brand new unit.
Wires from breaker are probably reversed with wires from Load
Call Intermatic.
Or copy following link for wiring:
T172 timer wires identical to T102:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T102
Nov 11, 2012 | Intermatic T172 24 HOURS 40 AMP 208 277...
Just intstalled a T104M according to the diagram and all the diagrams found on the web. The clock timer doesn't work. I can manually shut off the pump from the timer. I thought it was a bad tim
T104M is 208-277 timer mechanism that fits inside any Intermatic enclosure.
If voltage is not correct, then clock motor will not operate.
Since you did not say what voltage, I assume you have 240Volt pool pump.
Open following link to see the many ways to wire this timer:
It is possible that you have the Load and Line wires reversed.
Line wire come from circuit breaker, and Load wires go to pump.
If the T104M mechanism is part of a control panel with more than one timer, and/or a freeze control, then re-post question with more specific information.
Jun 23, 2012 | Intermatic T104 24h 208-277v Mechanical...
Intermatic T103P Timer (120V) Wiring Guidance
Copy following link for T103 timer wiring options:
The clock motor is 120Volts, but clock motor can be changed from WH1570 to WG1573, and this action changes 120V T103 into 208-277V T104 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Jun 08, 2012 | Intermatic Hardware & Accessories
How do i wire diehl t85 type 600
1) Copy following links for wiring Deihl T85 600 timer.
http://waterheatertimer.org/images/Deihl-Type-600-T85-timer.jpg
http://waterheatertimer.org/images/Deihl-T85-600-wired-for-208-230-Volt.jpg
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#T85
2) This timer will turn off Hot wire in 120Volt circuit.
3) For 208-230 Volt applications, the timer will operate by turning off 1 hot leg. However other hot leg will still have live power. To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
Feb 28, 2012 | Diehl Hardware & Accessories
Need wiring diagram for T104M 208-277v Mech. Time Time Switch
Here is the basic instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Below is a larger and better diagram of a 240V connection Terminal connections are White to White on 3 & 4 Black to Black on 1 & 2:
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
More info: http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
I am assuming you have the 240 VAC clock motor so the clock timer motor wires are connected to terminals 1 and 3.
If you only have the 120 VAC clock motor the wires will be connected across terminals 1 and 2.
Thanks for choosing FixYa,
Kelly
Jun 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
Will not shut off.
Ok is that the correct model number and voltage? Do you have it connected to 208-277 volts? (230V at home) Is the dial turning? Do you have both on and off trippers installed on the dial (they are not the same). If all that is true be sure the two timer motor wires are on the same incomine L1 and L2 terminals so it will run
Jul 31, 2010 | Intermatic T104R 208-277Volt 40-amp Timer...
Hello i have an intermatic model #t104r 208-277 volt my problem is that it works manually but it doesnt work automatically? whats wrong?
If you can also manually turn the dial so that the load turns ON and OFF, then the timer motor is bad :-( Replacements are available here for about $30:
http://www.aplussupply.com/intermatic/timer.htm
Scroll down to "WG 1573", Timer motor 208-277"
Dec 10, 2009 | Intermatic T104R 208-277Volt 40-amp Timer...
Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro Logo
260 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
