Question about Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range
Dacor ER36DSCH/NG Fan noise
After my new Dacor Epicure heats up (bake or convection) there is a terrible vibration that seems to be coming from maybe a venting fan? I can hear a fan running just fine (not the convection fan) and then this terrible vibration kicks in like maybe a second fan is trying to come on and is stuck or hitting something. It comes from the top of the oven, the empty space just below the burners. It is quite loud. Any help is appreciated. The range is brand new and installed by my contractor.
patrick
  • 833 Answers
SOURCE: Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
Posted on Dec 07, 2007
SOURCE: Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Posted on Nov 20, 2008
jumptrout51
  • 3361 Answers
SOURCE: dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Posted on Mar 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
Posted on May 05, 2009
  • 288 Answers
SOURCE: Oven will not heat
Heating elements are protected by a fusable link that is a one time fuse that is meant to protect the stove from overheating. It sounds like the elements need to be replaced
Posted on Jan 19, 2010
Large oven in dacor dual oven range broiler comes on when i select bake
on bake both bake and broil will come on the broil shuts down around 260 deg
this is normal its done to shorten preheat time
Jun 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven will not heat; convection fan runs when in convection mode, but elements won't heat for convection bake, pure convection, bake, or broil; it comes on as if it's going to work but the temp gauge never...
Jan 19, 2010 | Dacor Preference RSD30 Gas Kitchen Range
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
We have same range and are looking to convert from LP to NG
Hi some models will not convert to lp to nat gas , matbe you can sell it or do a swap with some one not much help sorry
Aug 12, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
