Question about Sub-Zero 611 / O Bottom Freezer Refrigerator
Recently moved into a new apartment that has a Subzero 611 Just put in 4 new light bulbs and none of them are working
  • 71 Answers
Try the light switch. located in the upper part of the fridge or freezer. is the white switch. the black an white is for the fan. REALLY EASY
Posted on Apr 02, 2010
I pull off tail light assembly took 4 screws out, but assembly wont came apart, is there a trick to it???
You probably don't need to take the assembly apart. The sockets holding the bulbs are probably visible. Just take the bulb holder and rotate it firmly about 1/4 turn counter clockwise, and it should come out of the assembly. Remove the burned out bulb, insert the replacement, check that it works, then put the holder back into the tail light assembly, rotating it 1/4 turn clockwise to lock it in.
Dec 03, 2016 | Dodge Cars & Trucks
Brake light problem
Make sure you have the right bulb. I've seen several times where the wrong bulb was installed.
Apr 08, 2016 | 2007 Lincoln MKZ
Right brake light does not work we have changed the light bulb and the socket but it still does not work?
Have you checked the fuses?
Have you checked that that new bulb is working? Put the new bulb in the left side, if it works, the bulb is OK.
If none of the above and you have a new socket, then there is a break in the wiring. Good luck with trying to find that, so go to an auto-electrician.
Aug 17, 2015 | Cars & Trucks
Lights and fan not working on my microwave
was the fan working before you replaced the bulbs? Did you check the old bulbs ie filaments broken....if two bulbs stopped working at the same time probability suggests that the problem was not the bulbs, especially since the breaker fired when you put in new bulbs.
Could be a short inside ...if you are not brave enough to take it apart and inspect better you take to be looked at ...better a fried microwave than a fried you...
May 29, 2012 | Microwave Ovens
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
One of my headlight went out but i jus recently put a new bulb in it???? what could it be?
get thecar tested for overcharging.if it's not the bulb may jusr have been defective of if it was a halogen bulb it may have been touched and the oil from your finger tips can make them blow prematurely.
Sep 30, 2009 | 1999 Dodge Stratus
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
169 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
