Question about Kenmore Sewing Machines
Kenmore 158-13472 Sew machine crank will not turn when foot pedal in on. Hand wheel turns with no problem, belts are good,crank turns by hand. My quess is the bushing. Anyone? Thanks.
  • 4 Answers
SOURCE: when I turn on my PFAFF 1222 it wont sew
It may be in bobbin filling mode. Can you turn the inner circular on the hand crank. If you can click it into position, this should engage the needle mechanism.
Posted on Jun 14, 2009
SOURCE: the foot pedal does not make the machine sew but
you did not say the model or maker of machine but from my experience, their are some model from brother where the belt slips off the motor pulley, this could be your problem.
Posted on Aug 04, 2009
  • 980 Answers
SOURCE: The machine will not sew by using the foot peddle.
The belt may have come off or may be slipping and the only way to check is to get inside the machine which will be very difficult if your machine has a two piece body
Posted on Oct 25, 2009
  • 1116 Answers
SOURCE: brother ls2725 foot pedal
http://www.sewingmachinesplus.com/J00360051.php
Posted on Mar 05, 2010
SOURCE: My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Posted on Mar 24, 2010
My vintage kenmore hand wheel was frozen now it turns manually but not when I use the foot pedal, then it won't turn
Either you will replace the belt or have to adjust the motor/belt tension.
1. The motor can be loosened by a couple of bolts. This allows the motor to be moved to adjust the tension of the belt.
2. The tension can be adjusted properly by turning the motor on with the foot pedal; low speed.
3. While the motor is running move the motor in a fashion that will loosen or tighten the belt. The correct location will allow the motor to run at it's highest speed.
4. Re-tighten the bolts and retest the machine.
May 04, 2017 | Kenmore Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Sorry the needle is not going down,
Needles will not go down for:
1. The lock on the hand wheel isn't locking. Try this
a. Loosen the lock like you're going to wind a bobbin.
b. Loosen screw that is on the side of the lock. (sometimes front)
c. Tighten the lock just like when you're going to sew.
d. Tighten the screw that is on the side of the lock.(sometimes front)
e. Turn hand wheel by hand. Did the needle rise and fall?
2. The drive belt isn't moving the shaft.
a. Remove the top of the sewing machine.
b. You will most likely have to remove the panel on the end where the hand wheel is.
c. Turn your hand wheel to see if the belt is moving the shaft or is it broken?
d. Replace if you need to. (look at wear). Loosen the motor.
e. Make your motor run (foot pedal) slowly. Tighten the belt by pushing on the motor while it is running. When the motor is placed at the right place the motor will be moving with very little drag. (This will need a listening ear)
f. At this point tighten motor and retest for the speed and drag.
Mar 21, 2015 | Sewing Machines
Hand wheel will not move easily
it sounds like the machine is ready to be serviced, the machine
could have a broken or loose part.
Dec 22, 2012 | Sewing Machines
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
The foot pedal makes noise, but won't turn bobbin.
only having the machine check at a sewing machine repair shop can say for sure
Mar 26, 2012 | Kenmore Sewing Machines
Won't sew when foot pedal is pressed
foot pedals do fail and possibly your s has .
Oct 31, 2017 | Kenmore Sewing Machines
I have everything in place to sew, the needle is in the fabric, I push the pedal, and it won't go and makes a horrible noise, the wheel turns about 1/2 a turn and then just stops.
see if it will work without the needle .. make sure the needle is not bent .. make sure you dont have a single (non zigzag) foot on the machine while its in zig zag mode .. the needle will hit the foot in this case .. if the machine will run without a needle and fails even with a straight needle then there could be a timing issue .. the top part of the sewing machine is syncronized with the bottom part via a shaft and some gears .. these are adjustable by a tech person .. everything has to happen at the right time if that relationship is changed thru slipage or wear then the machine may jam up .. also if some cloth, thread or lint is cought in the bottom unit it can cause the trouble .. will it turn by hand ?? if it turns by hand freely but wont turn with the motor ... and it makes a lot of noise .. you may have a loose belt from the motor .. if its a cog belt then it will make a shuddering noise as the drive gear slips over the cogs .. the belt tension is adjustable .. it just wants to be snug not tight, not loose ..
Sep 19, 2009 | Singer 7444 Mechanical Sewing Machine
When I turn on my PFAFF 1222 it wont sew
Jun 14, 2009 | PfaFF Sewing Machines
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
