Question about Toshiba Computers & Internet
Power up computer. it shuts off after a beep in seconds?
  • 1,675 Answers
Sounds like a power supply fault or your motherboard is shorting did you recently put it in?
Posted on Jan 30, 2010
Computer won't start. gives an error code of 1 long beep, then 3 short beeps , then shuts off. has phonix bios
I would try the following steps, if these don't work, contact Acer.
1) Remove power cord and battery.
2) Hold down power button for 5 seconds.
3) Replace power cord and battery.
4) Try to turn machine on.
If these didn't fix it, it's a hardware issue. Contact Acer for warranty support.
Mar 01, 2011 | Acer Computers & Internet
I am tryng to start my computer and it comes on for only 2 seconds and it shut off
Any beeps as it boots up?
Check the power button is not sticking first. It needs to release after powering up the board, otherwise it will cause the comp to shut down.
Feb 09, 2010 | HP Compaq Presario F750US
Jvc mc200 powers up,beeps and shuts down within 2 seconds
have a jvcgr-smx750 . It was working fine but recently I powered it up with battery, without battery and just ac power cable. Both times it does power up and shows the screen for about 2 seconds, beeps, and then shuts off. Please help
Apr 12, 2009 | JVC Video Cameras
Will not start up
If it's not beeping during the first start up then it's not POSTing.  Beep means everything connected to it seems to be functional ie PnP
Try pulling out your memory and reseating it.   Try pulling out your battery for 5 minutes then plug in ac(without batt) and see if it will boot.  Try pulling your hard drive and reseat.  (access by covers on bottom...dont be scared. Touch something that's grounded just before you remove) If all this and still no full POST(with beep/s) then sounds like a new mobo or processor.
James Mac
Sep 09, 2008 | HP Pavilion dv9000z Notebook
When I turn the computer on it just beeps!
Press and HOLD the Power button for 5 seconds ...this will turn off computer ......her's a list of beep codes http://www.computerhope.com/beep.htm
These may help !
Try a different keyboard /mouse if you can /make sure NO pins are bent or missing on PS2 connection .....
When booting up computer hold the DEL key down this will take you into the BIOS.......Select LOAD DEFAULTS usually F10 ...you'll see it on bottom of screen .....Save when prompted and see if it boots......Good luck
Jun 03, 2008 | Gateway GT5220 PC Desktop
My Presario SR1750NX won't boot up
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
Feb 10, 2008 | HP Compaq Presario Media Center SR1750NX...
Power On trouble with Computer
If don't you have any beeps check maybe the power button stack.
If the power button pressed for four seconds then the computer normaly shut down.
Jan 11, 2008 | Abit KV7-V Motherboard
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Computers & Internet Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
