Question about LG DLE2514 Electric Dryer
I have an LG tromm dryer and I have error codes regarding check filter.. I cleaned all areas, but I cannot get lights to reset. Does anyone know how to clear this error code?
SOURCE: LG Tromm dryer now takes two cycles to dry a load
Rob, sounds like you're on the right track. The other things that could be bad is part of the heater coil is out or, less likely, that you have thermostat or high limit switch issues. These will likely require a service person to resolve. Good luck, sir.
Posted on Dec 24, 2007
futureloginn
  • 734 Answers
SOURCE: 2008 LG Dryer will not heat.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
SOURCE: my lg tromm DLG3788W gas dryer is not heating, it
I just cleaned those sensors at the bottom of the filter, it worked like a charm. The dryer is now drying perfectly, I did not know you were not supposed to use fabric sheets with this dryer. Now I know, Thank you for the good information.
Posted on Dec 20, 2009
  • 3 Answers
SOURCE: LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Posted on Dec 31, 2009
omaharox
  • 161 Answers
SOURCE: the check filter light keeps coming ob to my lg
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Posted on Jan 20, 2010
DLE747RM FRONT LOADER LG TROMME CHECK FILTER LIGHT FLASHING
this is nothing to worry about. Its just a reminder and not an error code.
Feb 03, 2013 | LG DLE2514 Electric Dryer
I have a lg tromm dle2514 dryer and the check filter light is on. I am willing to clean it (I've already cleaned the front filter area) I just have no idea where there is another filter
There is no other filter to clean other then the one lint filter.
I would check the dryer vent to make sure it's not restricted with lint build up or has any kinks in it. Also check the outside flapper at the end of the dryer vent to make sure it's clear of lint and able to open all the way.
If your dryer vent is ok and the lint screen is clean then I would remove the front of the dryer and check the blower/fan housing for lint build up.
Aug 04, 2011 | Dryers
I have a lg tromm dryer model #dleo442w. my check filter light blinks before i start it. how do i check filter? I always clean the lent trap so i know thats not it. thanks
Ours does the same thing. We bought it used so did not get a manuel with it, but I think it's the same thing. I think it flashes to get peoples attention. Maybe it's a safety feature to help prevent fires.
Nov 12, 2010 | LG Dryers
LGDLE0442W Dryer check filter light on. Flter clean dryer sounds like it wants to start but doesn't. Is there a reset button?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | LG DLE2514 Electric Dryer
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Jan 18, 2010 | LG DLE2514 Electric Dryer
LG Tromm dryer says clean filter and won't run. Filter is clean.
CHECK YOUR HOUSE VENTING. MANNY TIMES IF THE EXAUST AIR IS NOT GOING OUTSIDE FAST ENOUGH IT WILL GIVE YOU THE SAME ERROR.
Jan 15, 2010 | LG Dryers
Our LG TROMM DLG7188WM dryer has no heat
Several things can be the problem.
Is 220v present @ the outlet?
Heat element?
High limit thermostat?
Main computer?
Bad dryer cord? Ect...
Proabably time for a service call.
Jan 12, 2010 | LG Dryers
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
Lg dryer tromm dlg5988w flashes filter code will not dry
Check your filter, your vent and clean them well. Shut down the power and let it reset itself.
Jun 09, 2009 | Dryers
LG DLE2514 Electric Dryer Logo
280 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
