Question about Honeywell HZ-710 Oil Filled Radiator Heater
Heater does not heat when turned on. indicator light stays red
  • 111 Answers
Check oil overtemp senser or heating element, some of the newer ones have a circuit board with default codes, check for codes,unplug, plug back in and see if it works
Posted on Jan 31, 2010
My iheater 1500 will not turn back on.the red light is still on.
Defective heating element. The red light merely indicates power is being applied.
Dec 04, 2016 | Heating & Cooling
New replacement in-line heater (C3B54P0-3002AU0) inop.
Bath tub heaters will only maintain the water temperature in the bath. They will only heat the water approximately 1-2 degrees an hour.
Whatever water temperature you start with is what you will be able to maintain.
There is a red indicator light on the front of each heater indicating whether or not there is power to the unit when the tub is full of water and the water pump is turned on.
If there is a red light on then it has power to it and is working.
This heater will never feel warm to the touch.
There are three different styles of Bath Heaters available.
  • Tee Heater - installs on the discharge fitting on the pump
  • In-line Pressure - installs anywhere in the plumbing line before any jet.
  • In-line Vacuum Heater - installs before the suction of the pump
If the heater you purchased is installed in the wrong place it will not operate.
Rod
US Parts Center
Dec 04, 2013 | Maax Calla 6042 Bathtub - 101058-000
Heater turns on initially - green light comes on and it fires up, stays on for 5 seconds then switches off, followed by a continuous beeping sound.I have tried this several times and the same thing happens...
When you say it lights up is the green light changing to red to let us know the unit has sensed a flame? If you get a visible flame but no red light then this indicates either the flame sensor is fauly or the electronic board is faulty
Jul 26, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
It's not lighting it's not working I see motor is running and I think gas coming out but it's not lighting I turn off the funance
Turn the power off to the furnace, turn the thermostat to the highest heat setting then turn the power on. The fan may start for a brief period, then the combustion blower will start, after approx 90 seconds, the ignitor will light and heat up. You should be able to see a glowing in the burner lens. If you do not see a red glowing, similiar to a car lighter, that would indicate the ignitor may have failed. If after 3 attempts, the systems fails to light, there is a light on the circuit board that will flash, the number of flashes will indicate the reason for the fault.
Nov 13, 2009 | Goodman GMS90703BXA Heater
Indication light "RED" on continuously during operation. Unit fires up, heats up and blows hot air. Why is LED "RED" on when unit shuts down?
not knowing wich one is on, this red light could be your power indicator light..
it stays on during any operation,
you should be able to see it through the sight glass
if it were flashing,,,, there would be a problem
Oct 13, 2009 | Goodman GMS90703BXA Heater
Water not staying hot, i have a Bosh tankless water heater. i noticed that the less water i have comming in the longer the water heater indicator light stays on, resulting in hot water. As i release more...
I installed a tankless heater in my home, I had the same problem, I discovered that the unit was not adequate for the water flow that I needed, I went up to a bigger unit and solved my problems, check to see what the flow rate is recommened for yours
Oct 10, 2009 | Water Heaters
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Goodman gmp050-03 heater
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Dec 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Honeywell HZ-710 Oil Filled Radiator Heater Logo
183 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
