Question about Brother HL 5140 Laser Printer
The toner light is on and I've replaced my toner.
    Scholar:
  • 185 Answers
You probably forget to reset it.
Posted on Jan 30, 2010
Are u using brother toner???
Posted on Feb 25, 2010
Scx 3200 samsung status light
If you refiil the toner cartridge ,now must be change the cartridge chip.The chip countered the total copy,not how many time you refill the toner.The original chip working 1500 copies,change one new chip to 1,5K or 3 k or moreK(K=1000 copies).
Mar 26, 2013 | Samsung CLP 300 Laser Printer
4 black lines at every print
Mostly black lines prints due to problem in the Black toner cartridge. remove the Black toner out and inspect the toner drum, whether are their any black patch on the toner drum. If it so there's a problem in the black toner. Replace a new black toner and check.
Jan 24, 2013 | HP LaserJet CP1215 Color Printer
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
Where is the toner sensor on the toner holder in the DCP-7020 it keeps telling me toner is empty and toner should not be empty yet.
If you look at your toner cartridge you should be able to see a clear plastic circle. That's part of the toner level mechanism. I've gotten a few more prints out of my cartridges by putting a piece of tape over the clear plastic and coloring it black with a sharpie. However, there are other mechanisms used to gauge toner levels, and this will not be a permanent fix.
I've also gotten a little more life out of it by simply shaking the toner cartridge for about 15 minutes. It helps coat the inside and might break up chunks inside the cartridge itself.
Jun 16, 2011 | Brother DCP-7020 All-In-One Laser Printer
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
Problem with Xerox Phaser 6110 black toner.
Yeah it is a problem with the chip that is on the cartridge. You can go to the Xerox.com site and contact them directly by phone or e-mail.
Just once at the xerox.com site, select your country.
Jan 06, 2010 | Xerox Phaser 6110 Laser Printer
I´ve got a message on my oki C5510 mfp printer "Failed to get printer information - Check printer". I´ve checked all cables and everything is ok. The toner light and exclamation light staying lit...
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
Nov 08, 2009 | OKI C5510 MFP All-In-One Led Printer
Replace waste toner. what does it mean?
open the cartriage their are a waste toner in your cartriage cleane the cartriage then use
Oct 03, 2009 | Office Equipment & Supplies
Brother HL 5140 Laser Printer Logo
197 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
