Question about KitchenAid Refrigerators
I have a Kitchen Aid Superba, water dripping inside fridge area
I have a Kitchen Aid Superba, manfacture date 04-96, model #KTRS19KEWH01 Water is dripping inside the refrig area, from the back, towards the top. Any clue what could be happening?
  • 42 Answers
SOURCE: Kitchen Aid Superba
To the person who hears a clicking sound you are correct, the compressor is trying to start but is not starting and that causes the overload to trip (click) wait a short time and it all happens again. Either the start relay is bad or the compressor is locked up. Less than 1 year old should be in warranty. If you want to try to check the relay you will need to unplug it from the side of the compressor. Once removed try to shake it and if you hear a rattle noise the relay is bad. To test the compressor you would need a test tool or be very experienced to perform accurate test.
supertechks
Posted on Nov 22, 2007
  • 1073 Answers
SOURCE: water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
Posted on May 09, 2008
SOURCE: Kitchen Aid Superba refrigerator
the black panel that runds down the side of the refrigerator between the freezer and food storage area is very hot. also the small light in the freeezer is blinking even though i have it turned off
Posted on Aug 07, 2008
rylee_smith
  • 8619 Answers
SOURCE: water dipping on the inside of fridge towards back
Hi
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Please do rate this solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Posted on Mar 26, 2009
SOURCE: Kitchen aid -Superba 42,
The rubber door gaskets tend to crease often times causing the cold air to escape. If your door gaskets are OK it's time to call the repair man!
Posted on Apr 08, 2009
I have a kitchen aid superba side by side black with ice maker and water dispenser. Questain is I have it outside plugged in, during the day sun is on it, will this affected the feezer side from keeping...
yes, the insulation in the fridge is not designed to handle that kind of heat, and it being black only compounds the problem. eventually the refridgerator will overheat and fail. it doesnt need to be in the a/c, but it does need to be out of the sun
Sep 26, 2013 | KitchenAid Kitchen Aid Superba Series...
Water dispenser leaks all the time.
Hi,the leakage in your kitchen aid all the time is due to the fact that the water inlet valve of your refrigerator,hence water keeps dripping from the dispenser always.
The only solution to the problem,is to remove the back plate which covers the compartment at the bottom of the refrigerator and replace the water inlet valve.
However,the component part number for your model is; 4389177
Thanks and good luck.
Jun 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
Problem with water and ice
My kitchen aid superba sie by side stopped making ice. I've changed the water filter and did the trouble shooting options in the book. Everything else is fine. Can you give me any suggestions
Mar 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Problem with KitchenAid Superba KSRG25FK Side/Side Refrigerator
I found you looking for keep en mind kitchen aid is made by whirlpool good luck :) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504094
Jun 12, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Jun 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
No Ice From Kitchen Aid
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
20 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
