Question about Char-Broil Advantage 463453306
Temp will not get over 250, just changed gas bottle, doesn't seem to have good flow of gas
    Scholar:
  • 151 Answers
It could be the fuel regulator on the unit. Its that disk looking piece that has the threaded nipple that connects to the tank. Try to tap it with the handle of a screw driver to attempt to free the diaphram.
Posted on Feb 01, 2010
I have a Master Temp 250 pool heater that shows an AGS error on the back of the board. The heater runs for about 20 seconds then shuts off, any ideas?
AGS = Auto Gas Shutoff...
What is happening is the heater is monitoring (or sorta, by reasons difficult to explain here) Water Flow and Water Temperature. In this case, the AGS is triggered by a low water flow, or high Incoming Water Temp.
High internal water temp = triggered AGS.
If you have and can confirm, PROPER water flow, water temp coming into heater is Lower than 104°, then it is possible you have a faulty AGS.
But in most cases, it's only doing its job. Locate the reason for the fault, or why the AGS Switch turned the heater off.
Jun 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
My grill has full propane bottle but doesn't seem to be getting propane! Any help would be appreciated.
Check there is gas at the burners and that the orfices are not block or the burners are bot blocked .
Turn on burners let pressure out of line turn off tank remove gas line then reconnect to tank and turn on tank slowly see if this works
Mar 12, 2012 | Weber Baby Q Grill
Just bought a new Jenn-Air grill and cant get the temp past 250. Any ideas what i am doing wrong?
First, check that all the gas lines and flame bars are clear of any 'things' or bugs. I had a similar problem with a Webber grill and found out my problem was with the gas bottle. The new Overflow Protection Valve required on LP bottles can closed off or severly slow the flow of gas when the bottle is full and the valve is opened quickly. It will let enough gas flow to light the grill but won't let the fire get high enough to heat the grill up. Turn all the valves off on the grill and gas bottle. Open the gas bottle valve slowly then turn on the grill burner and try lighting it. If the flame is still very low try again or you have to let it burn at the low level until the OPV float drops down and the valve doesn't impede the gas flow. The best way to avoid this in the future is to not fill the gas bottle to the top when you have it refilled. Just ask the LP attendent to not fill it all the way.
Jun 06, 2011 | Garden
I just install hot point gas range in my kitchen and the range oven and burners flame fail to increase as I turn up the the knob. Also the oven does not get very hot, the temp may be about 300 to 350...
Sorry to read about your problem, I hope this helps you out.
you may have a defective gas flow regulator
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hotpoint Kitchen Ranges
My banshee pushes coolant out of the overflow
Typically, with this type of problem , you are dealing with a leaking head gasket. Compressed gas and air from the compression stroke is forcing gas past the head o-ring or gasket into the coolant side of the cylinder. The expanding air bubble forces coolant past the cap causing the bottle to over flow.
Aug 16, 2010 | 2002 Yamaha TT-R 250
Flame is low
try opening the tanks slower so the overfill protection device in the tank won't kick in and restrict the gas flow.
Nov 10, 2009 | Weber Genesis Silver A Grill
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
2003 Yamaha wrf 250 only runs with the choke on
possibly water in your fuel.... it's a small tank so just put about a quarter bottle of gas line antifreeze in the tank... it's alcohol so it will **** up the water. there is also the possibility the fuel is somewhat dirty... change the fuel filter as well
Robert
Feb 05, 2009 | 2003 Yamaha WR 250 F
Char-Broil Advantage 463453306 Logo
125 people viewed this question
Top Char-Broil Grilling Experts
paulcarew
Dean Gruber
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
