Question about Pioneer VSX-29TX Receiver
No audio output
After a few years of storage on the shelf, I get no audio output through the speaker (A or B) connections, nor the headphone jack.
Unit powers up and all controls appear functional, just no output.
  • 3 Answers
THE FIX - to audio problems that persist with the VSX-29TX and others using the AWX7272 DSP board is to replace the ROM on the DSP. My unit started failing on and off after 10 years of use! The intermittent DSP board is an Extremely Common and irritating Problem for this model! The replacement IC,(2) resistors + shipping and handling totaled $49.65 and my unit is finally fixed correctly! Don't believe other posts that you can get away with re-soldering; it will continue to fail again and again! Details of fix are:
Replacement for the old Pioneer ROM located at location IC 9374, should be done with the part PD6381A from Pioneer Electronics. You will also need to move (relocate) the 2 resistors (0 Ohm resistors) located at R9372 and R9371 to locations R9374 and R9373.
This component update applies to DSP boards marked as AWX7433, AWX7272.
This fix is validated (from Pioneer) on the VSX-26TX,VSX-27TX,& VSX-29TX it might also work in the VSX-908, VSX-908RDS and others as long as the same DSP board was used.
Let me caution and stress that surface mount soldering skills ARE REQUIRED to do this update! It also doesn't hurt to have excellent vision and/or an eye loop or microscope to check your work. Original ROM's were subject to timing changes internal to the part as a result of HEAT. This model does get HOT! The program was also modified as a further safeguard to re-occurrence.
Posted on Apr 15, 2010
When plugging in a wireless headphone in the audio output the tv's speakers shut down.How can I stop this
The speaker cutout feature whenever the headphone jack is connected is a hard-wired feature of the headphone connector, and cannot normally be bypassed without further electronic circuitry and the associated surgery to install a custom modification in the TV. In order to keep the TV speakers on while using the sound elsewhere, you will have to take the audio output from the IR Audio port, if there is one.
Apr 02, 2015 | Olevia LT37HVS 37 in. LCD HDTV
Unable to hear system through speakers,but ok through headphones
Make certain the connections to your speakers are good. Test each of your speakers with a 1.5 battery. Put the + and - ends of the battery to the + & - of the speaker (not connected to amp). Just for a short time only - the speaker should "pop".
If they are good you might have damaged the headphone socket on the machine. These disconnect the speakers when the headphone jack is inserted. Sometimes the contacts break or become bent out of place thus not reconnecting the speakers. This can be easily fixed and is not an expensive repair. The only exception would be if there is a switch to switch off the speakers on the unit itself. But if in the past you have put a headphone jack in the unit when the speakers were operating and they cut off then a faulty jack socket is to blame.
Feb 06, 2015 | Audio Players & Recorders
No sound comes out of the system/speakers on my FW-C255/37
There is a problem with the headphone jack or there is a audio output problem, get some electronic contact cleaner attach straw and spray inside the jack, push the headphone jack in and out quickly and spray again and repeat, this should clean the contact points, if no sound, audio output should be suspect.
May 10, 2012 | Philips FWC255 CD Shelf System
Will not play through speakers works with headphones check speakers with another stereo and they work
This I have run across a number times, it is one of two things, the audio output ic pack is bad in the unit, or the earphone jack is clogged up. Get a small can of contact cleaner attach straw, give it one or two shots and use your headphone to push it in and out several times to clean the points, if this fails you must change the ic.
Feb 04, 2011 | Philips FWC555 CD Shelf System
What are the correct speaker connectors for this unit RCA, Phono ,3.5 mm ?
Does it have a speaker output - I'm sure it does? More likely it's the 3.5mm. which may look like for headphones. The RCA are for low level signals so therefore it's not for the speakers. Do the speakers have two wires a piece? If they are, then there should be speaker output clips on the stereo to connect to. If they look like phono plugs then they go into the speaker output jacks.
Oct 25, 2010 | GPX S7799 Shelf System
Can this unit be connected to my computer so I can make cd's?
It can if your computer has a 3.5mm jack audio imput.
What you need to have on your unit is and audio out socket. But if it doesn't have one you can use the headphone output. Then all you need is a lead. If you have the output sockets you just need a 3.5 jack to two RCA phono plugs one. If not you will need a 3.5 to 3.5 lead.
If using the headphone output, keep the volume low, use the computer recording device to adjust the signal level. NEVER turn the volume up high. Again if you are using the headphone output set tone controls to neutral, otherwise you will have either too much bass or treble on your recordings.
You can use the computer speakers to monitor the sound. Or you can get a headphone adapter plug that will allow to jacks to go into the headphone output of your unit, so you can connect a pair of headphones, but as I said don't mess with the volume control.
Feb 05, 2010 | Aiwa Z-R555 Shelf System
My sony 771 won t play any sound -- not the speakers because doesn't come through headphones either. Just cleaned the lens for CDs last night, then this problem developed. Can see the amp bars moving, so...
The lit indication ("amp bars") proves that the aduio signal is getting through the unit's circuitry @ least to that point; lack of sound @ the spkr & headphones indicates the amplifier portion of the circuitry is either inoperative or disconnected from the load (i.e., either the speakers, or the headphones). A common cause of this type of problem cropping up unexpectedly is the headphone jack itself; in most products of this type, the audio path from the amplifier output to the speaker connection runs through the headphone jack, so the the speakers may be "turned off" when the headphones' plug is inserted into the jack. If the unit's owner uses headphones regularly, the most common problem to be found with the jack is loose solder connections to the printed circuit board's traces from the jacks' lead(s); in units with this problem whose owner's irregularly use the headphones, it's more common to find oxidization of the electrical contacts within the jack itself.
Dec 10, 2009 | Sony Audio Players & Recorders
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
Pioneer VSX-29TX Receiver Logo
870 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
