Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't get picture for vhs's
I can get picture and sound when I play DVD's but only sound when I ply VCR's. I own a 47" Panasonic rear projection television if that is any help with high definition obtion (I don't have it hooked up).
The simplest thing --- I turned my television station to channel 3 and voila I got a picture to go with the sound. With all the newer stuff going on with dvd's hi-def and everything else the old way just totally slipped my mind. LOL
Posted on Feb 18, 2008
I am trying to hook up my vcr and my DVD to the 60pp9202 60 in my DVD is working but my VCR is not. I am getting a black and white picture on one channel and sound on the other.
put the dvd plug scart into the spare scart socket on the vhs player,then u can only use one player at a time,ie if watching dvd put vhs player into standby or vice versa,the other scart socket on the vhs player goes to the tv. when not using either be sure to put both on standby.
Feb 28, 2010 | Philips 60PP9202 60" Rear Projection...
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
No picture when connecting CRT TV to Panasonic DVD/VHS Combo
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
Feb 14, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
I want to convert a DVD to a VCR tape.
Do you want copy dvd movie on VHS tape?
Use DVD/ VHS Combo Player like shown in below picture...
Oct 27, 2008 | Televison & Video
Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Jul 13, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Split screen question
Only if you have 1 Ant input, if you have ant 1 & 2 then you don't need a vcr for split screen.
Feb 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
