Question about Epson Stylus NX400 InkJet Printer
When I do a nozzle check (I've cleaned the heads several times) there is no black ink in the printout and the blue ink is spotty.
  • 677 Answers
Are you using Genunine Cartridges!!!!
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 01, 2010
Cleaning head and nozzles
Cleaning the Print Head
r_bullet.gifUsing the Head Cleaning utility
r_bullet.gifUsing the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
  • Print head cleaning uses both color and black inks. To avoid wasting ink, clean the print head only if the copy quality drops (for example, blurred printout, incorrect or missing color.)
  • Use the nozzle check first to confirm that the print head needs to be cleaned. This saves ink.
  • When the Error light is on and a message appears on the LCD panel to prompt you to replace the ink cartridge or to indicate the ink is low, you cannot clean the print head. In this case, replace the appropriate ink cartridge first.
Refer to the appropriate section below to use the Head Cleaning utility.
For Windows
Follow the steps below to clean the print head using the Head Cleaning utility.
r_1.gifMake sure that A4 or Letter size paper is loaded in the sheet feeder.
r_2.gifMake sure that this product is on and the ! Error light is off.
r_3.gifAccess the printer software.r_arrow2.gifAccessing the Printer Software for Windows
r_4.gifClick the Maintenance tab, then click the Head Cleaning button.
r_5.gifFollow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
r_space.gifr_caut.gifCaution:r_space.gifr_space.gifNever turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
r_6.gifWhen Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
  • If the copy quality has not improved after repeating this procedure four or five times, turn this product off and leave it alone overnight. Then, perform the nozzle check again and repeat the head cleaning if necessary.
  • If the copy quality still has not improved, one or both of your ink cartridges may be old or damaged and may need to be replaced. To replace an ink cartridge before it is empty, see Replacing an Ink Cartridge. If the copy quality remains a problem after replacing the ink cartridges, contact your dealer.
  • To maintain good copy quality, we recommend copying a few pages at least once every month.
Apr 14, 2013 | Epson Stylus CX6400 All-In-One InkJet...
Epson CX5500 fault number 1180 Posted by Author imageGuest on 2/17/2013 Details Despite head cleaning and nozzle check several times, the fault persists. What can I do ??
How nozzle check result? Perfectly or Appear "another" lines.
Possibility: waste ink on the bottom plate of the head. Will disappear by itself, when used continuously. Try printing with enabling "Thick paper" option.
Feb 18, 2013 | Epson Office Equipment & Supplies
Replaced all ink cartridges and cyan does not print printer says the head is not clogged
clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem.
Please rate this solution. Thanks.
Nov 23, 2010 | Canon Pixma MP500 All-In-One InkJet...
I have a 4 month old epson sx215 printer... everything was working fine two days ago and today i went to print some very important documents and my black ink wont work... the inks are all full, I have done...
you have two option,
1.you can do nozzle check and head clean , many time can repeat, there is any improvement you can continue the same process.it will work
2.change print head(better go for new printer,you should understand one thing, Epson print head along with printer so, you have to take printout at least every day one copy,if you are using HP inkjet printer,this kind of problem you can solve every easily, just change cartridge only,because hp cartridge along with print head not with printer.
Sep 25, 2017 | Epson Office Equipment & Supplies
White stripes or bands running across the printout. I raelise that these are caused by some of ther print nozzles being blocked and have carried out the following: several clean head runs followed by...
have you done a print alignment.. You could also stand to take out the ink and clean the ink compartment with some q-tips and rubbing alcohol.
I hope this helps..
Nov 05, 2009 | Canon i350 InkJet Printer
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Oct 07, 2009 | Office Equipment & Supplies
Faint & White Lines in Printer Head Alignment
This sounds like you are using either a refilled cartridge or an after market cartridge and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity, alignment utility. This should clear up the problem with the spotty printout.
Oct 06, 2009 | Canon BJ I6500 InkJet Printer
My canon i6500 is missing line and washed out when printing.
This sounds like you are using either refilled cartridges or after market cartridges and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice, alignment utility. This should clear up the problem with the spotty and washed out printout.
Apr 07, 2009 | Canon BJ I6500 InkJet Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
224 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
