Question about Kenmore Elite 45986 Front Load Washer
The new four prong has a green, white, red, and black wires. The cord we removed is not color coded. Not sure what goes where besides green
    President:
  • 2,468 Answers
Red and black wires go to L1 and L2 power terminals and the white wire goes to the N- terminal "neutral" terminal and green is the metal unit case safety ground wire
Posted on Jan 30, 2010
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
Tip
3-prong to 4-prong Power Cord Conversion.
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards).
3-Prong or 4-Prong – The Difference:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Which One to Use: According to the National Electrical Code (NEC), Article 250, installations after the year 2000, require the use of a 4-prong plug which incorporates a separate ground and neutral wire. If you currently have a home that uses the 3-prong receptacle and cord, you can continue to use it. You will have to upgrade to a 4-prong configuration, however, if you plan on relocating your current receptacle, or if the internal wires of the receptacle become damaged in any way and require repair.
Converting from 3-prong to 4-prong: Make sure you UNPLUG the appliance prior to any repairs. CAUTION: Voltages dangerous to life are still present even with the appliance turned off and still plugged in. Notably in the area of the terminal block where the power cords are installed. You will need to remove the old cord by following these steps:
  1. With the appliance UNPLUGGED, remove the access panel on the back of the unit where the power cord enters.
  2. With the cover removed, you will see a terminal block where the power cord is attached. The terminal wires will be colored with the WHITE wire in the middle, and the BLACK and RED wires on either end. NOTE: There should be a green jumper wire or metal bonding strap attached to the NEUTRAL (white) terminal wire.
  3. Remove the terminal lugs holding the old power cord wires in place. CAUTION: Use care not to drop any nuts or screws inside the appliance.
  4. Remove the bonding strap or ground wire from the Neutral terminal lug. NOTE: If disconnecting a ground wire, make sure you re-attach it to the appliance frame.
  5. Loosen the screws on the strain relief connector that holds the power cord in place and remove old power cord. NOTE: If your appliance does not have a strain relief that clamps down and hold the power cord in place, it is highly recommended that you install one. This prevents chaffing of the power cord against the appliance casing, and prevents the terminal wires from being pulled and broken loose. This could pose a potential shock hazard or cause damage to the appliance.
  6. Install new power cord by threading it through the strain relief connector and tighten down the screws.
  7. Connect the new power cord to the corresponding colors at the terminal block (Black goes to Black, Red goes to Red, White goes to White). The difference is going to be a Green (ground) wire that will connect to the appliance frame. There’s usually a green grounding screw for this. NOTE: If you disconnected a green grounding strap in Step 4., you can connect these two wires at the same point.
  8. Re-install access cover. Turn off the service breaker to the appliance PRIOR to plugging it back in. With the breaker in the off position, plug the appliance in, and THEN turn the breaker on. In the event, something was wired incorrectly, it is far better to have your hands away from the receptacle and controlled from a distance. Safety first.
on Jul 16, 2008 | Whirlpool LER5636P Electric Dryer
Hi.i got a new dryer and its 3 prong but the house is 4 prong so i got a 4 prong and im not sure where the wires go. The diagram shows L1 N L2 than the green ground but the new 4 prong only has green red...
Ok. Let's simplify this for you. First and foremost you will want to remove the copper strip that goes from your center cord post the to case/cabinet of the dryer. This is to seperate your neutral and grounds within the machine. Some models used a green jumper wire instead of a copper strip but the idea is the same.
Now on the new cord the green (ground) wire is supposed to go to the connection point the copper strip used to go to on the cabinet. The white wire (neautral) is supposed to go to the center terminal connection on the terminal block and the red and black (L1 and L2) wires can go to either of the outside terminals.
The only difference in a four wire cord application is the segregation of the electrical neutral and the ground wires.
Good luck, hope this helps you!
Jun 26, 2010 | Frigidaire GLER341A Electric Dryer
How to connect a 4 prom receptical
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 04, 2010 | GE DSKP233EWWH Electric Portable Dryer
Dryer cord
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
How to hook up a ge dryer change from a THREE PRONG TO FOUR PRONG HOOK UP
Replace the old Three prong cord with a 4 prong.
White wire from 4 prong cord goes to the center terminal of the connector block. If there is a metallic strip on that terminal that goes to ground remove it from the terminal and bend it away from the terminal and down so it either touches the case or ends in thin air. Be sure it can't touch either of the outside terminals of the 3 terminal block.
Red and Black wires of cord go to outside terminals of the three terminal block. It makes no difference which one goes on which terminal but I usually attach them so the color of the cord wire matches the colors of the wires already on that terminal.
The last terminal is green and should be attached tightly to any screw of the case or any metal bracket attached to the case that it is long enough to reach as this is the ground. This lead protects you from electrocution if the dryer has an internal problem and should be tight to the case.
Sep 22, 2009 | Dryers
I NEED HELP CHANGING CORD TO A 4 PRONG ASAP!!THANKS
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Better? Best wishes and sorry about the pics. Hope this is better.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
I had to change the three prong wire and replace with four prong
If you are converting from 3 to 4 prong service, that is fairly simple and should be done as follows:
If you purchased a pre-terminated cord that has a molded plug on one end and four wires with lugs on the other then that is what you have to attach to your dryer. Start by pulling the dryer out far enough to gain easy access to the back panel. Depending on the model, you will need to find the place where the cord feeds through the back and feed the new wire through that opening ( there should be some kind of cable clamp that guides and clamps that cable through the back panel). Once fed through, look for the terminal block on the back of your dryer. You will have at least 3 terminals that should be color coded red, black white or green) Start by installing the red to red, black to black and white to white ( or green) and then take the green wire end of the cord and look for a ground stud on the back of the dryer. There should be a terminal or sheet metal screw that you can attach that green wire to the dryer. The green wire is a safety ground that bonds the dryer to earth ground and provides a path to ground through the dryer chassis should you develop a short top ground. That path is provided to protect you so that you don't become the path from power to ground. Hope that helps...
Just remember to do all this wiring with the cord unplugged from the power source...
Regards,
Rick
Nov 23, 2008 | Maytag Dryers
Electric dryer cord switch from 3 to four prongs when the wires aren't colored?
I wouldn't worry about that, make sure you can fully see the terminal block where the wires install. Left to right usually is black, white and red. Make sure green is on ground at the case and if there is a white wire there already, just add the green to it. The cord also on a 4 wire is coded so just line up the colors.
Aug 13, 2008 | LG DLE2514 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
91 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
