Question about Sony KP-53V80 53" Rear Projection Television
Selective "non-convergence" issues
My KP-53v80 was dropped off one step during the move from one house to another. The overall convergence is good, but I have issues in the upper left hand corner, I see red/blu/green images with a "wave" pattern. Also lower right hand convergence is off with same problem. Middle of picture is stellar. Focus is good. I'm lost...... any Ideas?
  • HippyPimp Nov 17, 2008
    I have the same problem. The blue dips low in the top left of my screen, but only in a small area. (eg "Video 1" is displayed normally, and then in blue below it.) Did this fix the problem? Are there just 3 pairs of yokes holding 3 tubes? I know little about TV's
    Novelist:
    Champion:
  • 211 Answers
Sounds like to may have a yoke loose on a tube. If it's not that, you may have somehow damaged the convergence board. Look for any cracks in the board. If you find any, solder across the beaks and it should be fine. Good luck and I hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
THE COLOR IS NOT ALIGNING UP. LOOKS LIKE A BLUE SHADOW IN THE CORNER. TRIED THE FLASH FOCUS BUTTON BUT NO GOOD
convergence chips are out..
here is my tutorial
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 14, 2010 | Sony KP-53V80 53" Rear Projection...
Sony KP-53v80
There may be an open fuse. The typical fuse for the application is a 3-amp, and may not look anything like your typical fuse. If you have sucessfully replaced the parts that you indicated, the convergence should be very close to what it was before the failure. The fuse may look like a small rectangle of black or white plastic with a wire through it.
Feb 02, 2010 | Sony KP-53V80 53" Rear Projection...
Sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
3 different images in color sony kp-53v80
Replace Both of your convergence ICs They are big black ICswill have part number on them STK392-110 Order the same # as your STKs have on them Call Mats for Parts 1-800-628-1118 also CK pico Fuses they look like resistors will be green or yellow they are fuses.
Sep 27, 2009 | Sony KP-53V80 53" Rear Projection...
I have double images in red on my screen any ideas?
You have a convergence problem, time to call for service.
it should run about $300
Jul 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp-53v80
Sounds like one of the tubes is shorting out causing the set to go into a shutdown status so it won't cause any major damage to the set or house.
Sep 06, 2008 | Sony KP-53V80 53" Rear Projection...
Blue convergence on KP-53V80
replace both of your STKs 392-120s.these are your convergence ics , I always replace with 392-180s better ics.this will fix your problem.
Dec 31, 2007 | Sony KP-53V80 53" Rear Projection...
Sony 52"
i have a sony kp-53v80 i have a double vision or red lines on the left side of the screen. a repair guy fix it once by using the remote and puting in a code that brought up a white grid and it showed the red was out of line and he moved it back in line and it only took a few seconds to fix ... how do i get to that grid using the remote
Dec 28, 2007 | Sony KP-53V80 53" Rear Projection...
The color keeps going out
The repair tech used cheap parts or did not replace both convergence chips.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 12, 2007 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53" Rear Projection Television Logo
66 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
