Question about Sport & Outdoor - Others
I have a Precor EFX5.17 elliptical. I keep getting an error message ERR44. how can i stop this from happening so i can complete a work out with out losing the information about it?
  • 3,230 Answers
Well first of all you can try the below steps -
1. When the elliptical is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2. Press the "ENTER" button three times to access the elliptical error log.
3. Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4. To view the elliptical odometer reading when a particular error code was elicited, press "SELECT" while a error code is displayed.
5. To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
Good Luck!!
Thanks
Posted on Jan 30, 2010
My precor elliptical keeps giving me error44
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Jun 26, 2014 | Precor EFX 546i Elliptical Version 4
CROSSRAMP ON PRECOR 546i DOESNT GO UP OR DOWN
I would definitely check the battery first. The battery may not have enough charge to power everything plus the lift motor.
Here's a link to the various 546i models:
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Drill it down on the left side under "narrow your search" and look for the serial number prefix. This will let you find all the correct parts and information specific to your model and serial number.
Jan 17, 2014 | Precor EFX 546i Elliptical Version 4
My Precor EFX 546 Elliptical machine has a "key depressed" error message.
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Aug 17, 2010 | Precor EFX 546i Elliptical Version 4
What is error 50 on the precor efx546
Error 50, Too Much Brake (Magnet) Current
The problem maybe lower board related or improper signal is being translated Call Precor @ 800-347-4404
May 11, 2010 | Precor EFX 546i Elliptical Version 4
Error message "key depressed" and no resistance on elliptical.
you will need a keypad and overlay call National Gym Supply @ 1-800 496-7278 they will need M & S #
Feb 06, 2010 | Precor EFX 546i Elliptical Version 4
The ramp will not go up or down. It's states low battery (546i precor)
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Dec 29, 2009 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Sport & Outdoor - Others Logo
104 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
