Can not open back panel - Televison & Video
  • 644 Answers
First Ensure all screws have been taken out, check for little plastic gromets that may be hiding screws, and run your fingers across any stickers somtimes they will hide screws, if positive all screws have been taken out then there is only plastic clicps holding the back on. Find the join between the front panel and back and gently slot a flat but strong item like a table knife an gently ease away, all the way around until it finally comes loose and you are able to remove it.
Hope this helps.
Posted on Jan 30, 2010
Cannot find motor for sunroof in 1998 lincoln towncar limo
Before removing the motor ,check for B+ at the switch , in an out of the switch . Lincoln calls this a moon roof an there is a relay that powers it up . The location of relay an the motor is in the same place ,center of headliner behind the roof .
  • Sliding Roof Panel Does Not Open or Close
  • Damaged circuit breaker.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
  • GO to Pinpoint Test E .
PINPOINT TEST E: SLIDING ROOF PANEL DOES NOT OPEN OR CLOSE E1 CHECK WINDOW OPERATION
  • Operate window.
Does window operate? Yes No GO to E2 . SERVICE safety relay circuits. REFER to Section 01-11 . E2 CHECK SUPPLY TO SLIDING ROOF PANEL MOTOR
  • Remove roof sliding panel switch as described.
  • Turn ignition switch to the RUN position.
  • Using a voltmeter connected to a known good ground, check Circuit 400 (LB/BK) at roof sliding panel switch connector C900 for voltage.
Is B+ present? Yes No GO to E3 . SERVICE open Circuit 400 (LB/BK). E3 CHECK SLIDING ROOF PANEL SWITCH GROUND
  • Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at roof sliding panel switch connector C900 . Measure resistance.
Is resistance 5 ohms or less? Yes No INSTALL roof sliding panel switch. GO to E4 . SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system. E4 CHECK CIRCUIT 692 (R)
  • Using voltmeter connected to ground, back probe Circuit 692 (R) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the open position.
Is B+ present? Yes No GO to E5 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E5 CHECK ROOF SLIDING PANEL SWITCH
  • Using voltmeter connected to ground, back probe Circuit 691 (DB) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the closed position.
Is B+ present? Yes No GO to E6 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E6 CHECK SLIDING ROOF PANEL MOTOR
  • Gain access to sliding roof panel motor as described.
  • Using voltmeter, back probe sliding roof panel motor Circuit (DB) at connector C903 .
Is B+ present? Yes No GO to E7 . SERVICE Circuit (DB) for open. RESTORE vehicle. RETEST system. E7 CHECK CIRCUIT 692 (R/Y)
  • Using voltmeter, back probe sliding roof panel motor Circuit (R/Y) at connector C903 .
Is B+ present? Yes No REPLACE damaged sliding roof panel motor. RESTORE vehicle. RETEST system. SERVICE Circuit (R/Y) for open. RESTORE vehicle. RETEST system.
Sep 20, 2015 | Lincoln Cars & Trucks
I have a Kenmore Elite dryer model #11087872602 that would not start or light up the panel on the front of the dryer. I had a general appliance repair man come out to look at it. He took both computer...
the start switch needs replaced, as far as the front panel light not lighting you will need to open the back top panel of the dryer and find the wiring diagram and trace it out, it may something as simple as the connector is unplugged. Hope this helps Tim
May 03, 2011 | Dryers
Canon printer mp160 sho erro E 2
Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Jan 19, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I had a major paper jam at my printer (Canon, Super G3, imageClass MF 4150). I removed all the paper which was not easy. The printer is not working and switches to following messages: Paper Jam, Lift panel...
  1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  2. Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  3. Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  4. Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  5. Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  6. Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  7. Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  8. Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Jan 26, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Paper jams /canon480
  • Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  • Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  • Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  • Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  • Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  • Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  • Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
  • Jan 26, 2010 | Office Equipment & Supplies
    Back hatch won't open.need info on getting it open.need info on getting the back panel off the inside of the hatch to get to the motorof it. the electric switch on the hatch window, has to be unlocked...
    your going to have to remove it from the inside, remove as many screws as you can that hold the panel on, then pry panel open until you can reach linkage to pop window and then linkage to open rear gate. good luck.
    Dec 20, 2009 | 2002 Chevrolet Blazer
    Sun roof will nt close cant find the rite fuse
    check fuse F1.401, 30 amp in central junction box (in truck). Check your owner manual for fuse information.
    Headliner must be removed to access motor.
    Visual Inspection Chart Mechanical Electrical
    • Roof opening panel
    • Roof opening panel frame
    • Roof opening panel drain hoses
    • Roof opening panel lifter assemblies
    • Roof opening panel water trough
    • Roof opening panel air deflector assembly
    • Roof opening panel seal
    • Roof opening panel shield
    • Battery junction box (BJB) fuse
    • Circuitry
    • Accessory delay relay
    • Roof opening panel switch
    • The roof opening panel does not open or close
    • Roof opening panel adjustment.
    • Battery junction box (BJB) fuse.
    • Circuitry.
    • Roof opening panel switch.
    • Roof opening panel motor assembly.
    • Roof opening panel lifter assemblies.
    • The roof opening panel does not open or close — one direction only
    • Circuitry.
    Apr 10, 2009 | 2003 Lincoln Navigator
    1998 Sienna Back Door Latch Stuck Open - Door will not open
    well to get the door open you have to get the panel off first remove the assist grip and the pull strap ure ganna need a 10mm socket then pry around the panel and pull it off carefully watch for clips that may have fall off there should be 11 clips once you get the panel off you shoul be able to open the door. GOOD LUCK!! hope thats usefull
    Jan 08, 2009 | 1998 Toyota Sienna
    Error Paper output slot the paper is jammed.
    2. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
    3. Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
    4. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
    5. Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
    6. Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
    7. Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
    8. Plug the printer’s power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
    Nov 23, 2008 | Canon Office Equipment & Supplies
    Dog left open and freezer not starting back to freeze
    freezer condenser is frosted over. Open frezzer and defrost manuly. Open door and panel in back comes off with six screws.
    Jun 17, 2008 | Samsung RS2630SH Side by Side Refrigerator
    Televison & Video Logo
    54 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
