Question about LG Microwave Ovens
LG lmvm2075st microwave control panel problems.
LG lmvm2075st microwave. I am on my third control panel. On each panel the board surrounding the same diode is burned. With the installation of the third control panel, the microwave now takes three times as long to heat food.
  • LG Master
  • 9,047 Answers
"On each panel the board surrounding the same diode is burned"?
Maybe that's a three-tap power relay, not a diode?
I'd be very interested in this and I have the service manual here which you can download.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
Also, if you can send me a photo of the burned area, that would be helpful.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 31, 2010
How do I find the fuses in Microwave
Mainly there are three/four fuses in Microwaves depend to maker.
First one to be checked it is on plug about 13A in cable out side microwave
Second one for power supply usually comes 10A located in terminal board of cable supply in side microwave if you follow the cable.
Third fuse i think about 5A for high voltage it located usually on wire connected between transformer and capacitor.
Fourth some Microwave have third one on the control board located behind switch panel.
now.
if the second fuse is blowing immediately after starting microwave that usually mean one or more of the following need to be replaced
1- diode
2- HV. capacitor
3- magnatiron
Which only can replaced by skill technicians
THANK YOU.
Oct 31, 2014 | Emerson MW8998B 0.9 Cu. Ft. Counter-Top...
Lg lmv1630bb microwave
Unless you are successful with a hard reset of the elctronics you are SOL and need to get a new control board. Check out the attached for parts Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Microwave Ovens
WHAT CAUSES MY LG MICROWAVE WILL ASK FOR TIME BUT WILL NOT STAY ON WHEN I SET COOKING TIME?
Possible fault with the control panel or the touch pad, remove the control board and customer panel, clean it thoroughly, warm if there is moisture or insect secretion which can be also on the board.
Feb 12, 2013 | LG Microwave Ovens
How do you remove the touchpad on a LG LMVM2075ST
see the video and proceed according. God bless you
Oct 15, 2012 | LG LMV1630ST Microwave Oven
Some panel buttons are not working on my LG LMV1630ST
The problem is in the keypad control board and must be replaced, I would consider cost before you allow the go ahead.
Apr 05, 2012 | LG LMV1630ST Microwave Oven
LG microwave oven that has a 2-level (Low & High) that lights the cook surface. The High level light does not work?
There could be a number of issues, A schematic would be of great help to determine how the lights operate / how they are controled. They might be controled directly off the control board, or via a step down transformer. The lights might have two filiments for low & high. There could be two light bulbs, where one is on for low & two for high. A two position switch could be bad for the high position.
Mar 27, 2012 | LG LMVM2075 Microwave Oven
Our LG LMVM2075ST microwave touch panel does not work. Is this worth repairing or is it a bad design?
Sorry to read about your problem, I hope this helps you out.
you will have to contact a service company, microwaves are complex. if you order a part and try to fix, their are no returns. plus lg parts take a long time to get, and then way the cost of repair.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | LG LMVM2075 1000 Watts Microwave Oven
LG microwave LMVM2075ST panel started acting crazy after I cleaned it. Will not do anything if I push a button except beeping noises. Any suggestions as to what is going on with this machine? Should I try...
liquid probably has entered keypad laminate; causing a short. unplug unit, direct warm hairdryer to entire keypad; plug back in; and hope for the best. if no luck; replace keypad. also never spray anything directly onto keypad; always clean with a moistened towel with light force.
Sep 07, 2009 | LG LMVM2075 Microwave Oven
Microwave Ovens Logo
801 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
