Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
When I use the HDMI input on my Sony Bravia KDL-40V2500 it will work for a while and then all of a sudden I will lose the picture
I have the same problem does your screen go black and have a bunch of white dots on it as well?
Posted on Jun 12, 2010
I'm trying to use my bravia as a computer monitor.
Your Bravia should have a 15 pin PC input, this input can take most standard PC resolutions, however if you a have a video card with an HDMI port, you should set your resolution to 1920 x 1080 @ 60Hz refresh rate so that the signal can be recognized and processed, many standard PC video resolutions are not compatible with the HDMI inputs. You should not require audio cables unless you are using a DVI to HDMI connection.
Crampy
Dec 11, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Dec 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Repairing Sony LCD tv
Try getting the TV menu on the screen. If you can't, it's probably the LCD panel or backlighting issues. If you look very closely sometimes you can see a dark image if it's backlighting issues.
If you can bring up the menu, but all inputs are black, then the problem is more towards the electronics. Usually computer VGA and HDMI inputs bypass a lot of electronics and may point you to a video switching issue in the TV. If this is all Greek, consider a trained service company. Choose a platinum servicer since they are Sony trained, certified and held to much higher standards than other authorized servicers. Sony expects them to make first attempt fix within 5 days of contacting Sony. Usually the right part is sent to the tech prior to them setting the repair appointment. Compare that with the others and you will see a clear difference.
Jul 27, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia Kdl-40V2500
No probably not The Brd he is talking about is the BU Brd does your component video work
May 15, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Can't remove AV Input display
Try setting hdmi control to off in tv menu
Apr 06, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia 40"
Do you have a cable or satellite box connected to the tv?
Dec 31, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
501 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
