Question about Kenmore Dishwashers
The water is not draining completely - Kenmore Dishwashers
  • 706 Answers
Hello dmcgillvray1,
You aren't giving me much information to go on but I will point out some basic checks for you to do... First off, make sure you clean the filter screen where the water drains out of the dishwasher pan ( should be at some low point and needs to be free of any food byproducts that may restrict drainage... That said, if your dishwasher drains int a garbage disposal into your kitchen sink, make sure that it is clean of any garbage... (cycle it with water running to ensure there aren't any obstructions)... Those are the main culprets but you could have other issues... the pump itself is clogged, the lines feeding or exitting the pump are clooged or restricing flow... your house drain may be restrictive and limiting flow... Check the drain line that runs from the dishwasher to the drain itself to make sure it is not pinched off or clogged. I have used this technique a few times to verify the flow .... I have unhooked the dishwasher drain from the house drain ( normally under the sink and just by loosening a hose clamp... then using a large pail... started cycling the dishwasher ... when the dishwasher starts the drain cycle.. look for a very good flow of water.. if it is flowing good, then the problem is not the dishwasher and may be related to the house drain... Be careful not to over fill the bucket and it should fill up fairly quickly.. alternatively, you may be able to use a flashlight and look into the sink drain while the system is draining to look at flow... f it seems weak.. then you may have any one of the other problems mentioned previously.. Hope that helps...
Posted on Jan 30, 2010
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
Asko fifteen eighty five dishwasher completes cycle, but the drain cup area still has water in it.
The drain cup normally has water in it after it drains. The pump runs it empty, but when it stops, some water runs back down from the drain hose, which you see in the drain cup. If there is water in the bottom of the tub, you may be having some siphoning coming back after draining. Check to make sure the drain hose has been routed up to the bottom of the countertop as per the installation instructions. That's what prevents siphoning, and its very important so it doesn't suck sewer water back in with the clean dishes!!
Jul 08, 2014 | Asko 24 in. D3250 Built-in Dishwasher
After wash complete unit will not drain complete, water remains in filter trap. this water will smell after a short time.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 06, 2010 | Bosch Dishwashers
Dishwasher will not go through complete cycle it will not take water away
most washing machines nowadays have a electrically operated switch that will open to either drain or let in water if ur machine does not drain the water the machine will not go ahead in completing its cycle as the sensors sense that there is water in the drum so unless the water drains u will have this problem. Check for a click sound when the machine reaches a point to drain if that doesn't happen then it is this drain switch that isn't working
Jul 01, 2009 | Electrolux Dishwashers
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
Whirlpool dishwasher is not fully draining after cycle complete
THE PROBLEM SOUNDS TO BE WITH THE INSTALLATION OF THE DISHWASHER ITSELF. YOU NEED TO MAKE SURE YOUR DRAIN HOSE IS NOT KINKED AND ALSO THAT THE DRAIN HOSE FORMS A LOOP. IN OTHER WORDS IT SHOULD GO STRAIGHT UP BEHIND THE UNIT AND THEN DOWN INTO THE SINK OR DISPOSAL.THIS SHOULD TAKE CARE OF YOUR PROBLEM.
Apr 07, 2009 | Dishwashers
Dishwashers Logo
131 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
