Mitsubishi, M-PF5350 After changing the battery on the remote and using the remote to power off the M-PF5350 suddenly the power is completely gone on the amplifier.  You can not power on the amplifier any more.  It has no power at all.  Please help!
  • Anonymous Jan 21, 2009
    Hey can u help me please? i have the same reciver. contact me 0108499@up.edu.mx
3 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Posted on Mar 06, 2009
  • 255 Answers
SOURCE: Universal Remote frozen
I have taken the batteries out and put them in backwards, taken them back out and put them in correctly. Then I reprogrammed the remote. This usually works, although I wouldn't put it on the "recommended" fixes shelf. But you might want to give it a try.
Posted on Nov 26, 2009
My fire stick remote won’t respond to Alexa commands from remote
hi Douglas298.
this is all i could find.
Fire TV Remote NOT Responding / Syncing / Connecting: SOLVED I've changed the Fire TV Voice Remote control batteries 5 times already but it still keeps disconnecting and now it's gone completely dead! Update 08/02/17: The most probable cause for your Fire TV remote not working is going to be the batteries. I know, you're thinking I've already changed the batteries twice already. The Fire TV remote is a fickle beast and only likes brand new fully charged batteries before it will re-connect to your Fire TV box. I've tried switching in batteries from other devices that are all working fine, but without any success. Brand new batteries are the key for this power hungry remote.
Has your Amazon Fire TV Box or Fire TV Stick become slow? See my Fire TV Slowdown Solution here.
This need for new batteries seems to be especially true when your Fire TV box is next to a complicated TV setup with AV, Speakers, WiFi Router all next to each other.
AMAZON FIRE TV 4K
AMAZON FIRE TV STICK
If you've tried brand new out of the packet batteries and it's still not working then you might have the same issue I had below. Don't forget to ask any questions you might have in the comments beneath this article.
Update: You can now control you Fire TV Device with the Amazon Echo & Amazon Echo Dot
If you've felt the annoyance of your Fire TV Voice Remote suddenly not connecting then I know how you feel. I've owned a Fire TV since October 2014 and up to now it's handled everything I've thrown at it. This is until one day last week when the remote suddenly kept disconnecting then died completely showing no signs of life.
I went through an array of different fixes to try and get it to work again but then finally I had a brainwave and managed to bring the remote back to life. It wasn't through trawling internet blogs and YouTube videos that I found this solution, it was actually from inspecting the remote more carefully. No, it wasn't Amazon's fault for building inferior products it was actually my own fault and partly the fault of cheap pound stores that litter the UK.
When I took the battery compartment off the Fire TV remote it looked completely normal. It wasn't until I raised the remote up to eye level that I noticed that there was a slight chalky residue on the connectors of the battery compartment. It then dawned on me as I looked across the room at a packet cheap pound shop batteries. One of the cheap batteries had leaked battery acid on to the Fire TV remote connectors blocking the current from getting through.
How to use your Fire TV when the remote won't turn on?
Luckily, Amazon have an App for that called Amazon Fire TV Remote that is available in the Android App Store and the Apple App Store. You can then control the Fire TV using the app and proceed to the next step below.
How to check if your Fire TV remote is connected to your Fire TV?
To see if your Fire TV remote is connecting to your Fire TV box or dongle you need to head to the settings menu.
  1. Settings > Controllers and Bluetooth Devices.
  2. Amazon Fire TV Remotes
This will show you what devices are currently paired and from here you can see if your remote is connecting. In my case when fiddling with the batteries my remote would appear here for a few minutes then disappear.
If all else fails, you can get an official Amazon FireTV Remote replacement.
The Solution
I took a flat head screwdriver and gently scraped the connectors of the Remote at each end. Wiping the residue off with a dry cloth as I scraped. The connector should look shiny and new again at the end of this process. I placed the batteries back in and the remote connected again straight away.
I've had no problems with the remote since and I guess the moral of the story is sometimes you get what you pay for... utter leaky batteries this time.
Fire TV Quick Tips
  1. Hold down the Select button for 5 seconds to put the remote into pair mode.
  2. Hold down the Select + Play buttons together for 5 seconds to Restart the device.
  3. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in.
  4. or try this link.
fire stick remote wont respond to Alexa commands from remote Google Search
Nov 29, 2017 | Televison & Video
Why does plasma tv not come on?
Check the power outlet. Try connecting it to a different power outlet. Look for any jammed buttons on remote. Retry by removing batteries of the remote and operating the TV from the control panel. If nothing works, the power supply has gone bad. It could also be a blown fuse.
Aug 03, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
2005 mitsubishi endeavor the keyless entry works on all doors but the main one
locking solenoid has failed, might be the wiring in the door or the motor its self has gone.
Jul 28, 2017 | 2005 Mitsubishi Endeavor
Mitsubishi WS-65511 volume control has gone crazy. All of a sudden volume went to full blast and now with manually pressing volume button it is either full volume or lowest volume. We have DISH and...
Mitsubishi WS-65511 volume control went crazy after a storm. Now we don't having any volume. None of the controls are working on the front of the panel with the exception of the device control.
Jun 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Norelco shaver sudden power loss
I hope you are observing the following:- Recharging only when the batteries are almost completely empty. Continuously recharging or continuously using as a corded razor will reduce life of batteries Charge only when the indicator in charge meter starts blinking. It appears that your batteries are gone. Hope you have replaced the batteries with the new ones. Use a good brand
May 14, 2010 | Norelco Quadra 7885 XL Electric Shaver
Mitsubishi 65807 won't power on
hello it's possible the glass fuse may blown inside the tv take the back off and check but make sure the power's off
shaun
Oct 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Picture and sound go out and remote isn't working properly
Take the original Mitsubishi remote and remove the batteries. Install new fresh batteries and then try to operate the set. Do not try to use any of the inputs that are active. Just check menu funtions with the mits remote. All kinda irrational stuff happens when multiple and universal remotes get involved. If this a model remote that has a selector switch at the top for choosing tv/sat/vcr, etc make sure it's on tv.
May 28, 2009 | Mitsubishi WS-55515 55" Rear Projection...
IRiver H320 is completely dead
you can change battery and/or upgrade hard drive (if changing hard drive, save the software to pc then copy to new hard drive)
how to replace battery / hard drive
check and follow this link http://www.youtube.com/watch?v=6HOnpHSgMvw
if you dont have tools http://www.ipods99.com/Default.asp?Redirected=Y
Sep 18, 2008 | iRiver T20 MP3 Player
Dell inspiron 600m idle battery
the battery has gone bad and needs replaced, also check manufacturers web site to see if the battery is on recall, may be get it for free.
Nov 12, 2007 | Dell InspironTM 600m Notebook
183 people viewed this question
 Grubhead
Grubhead
