Question about Poulan Garden
Will not run new fuel lines but does not crank, poulan micro xxv
Will not run new fuel lines but does not crank will run if fuel is droped in to carb fuel lines shoes fuel about half way
    President:
  • 2,220 Answers
I suspect hose routing may be in error. Is it like this?
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If it is, please reply below and we will continue with an attempted repair. I hope you found this most helpful.
Lou
Posted on Jan 30, 2010
Trying to find a service manual for this. can you assist? thanks
Hi Linda:
Here's a link that will get a lot of sites where you may be able to get the manual. Just click on it.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Poulan+Micro+Xxv+Vintage+Chainsaw+service+manual
Hope this helps.
Keep those old machines running!
Cheers
Apr 02, 2016 | Poulan Micro Xxv Vintage Chainsaw Coil...
How do you adjust the carbrater on a poulan micro XXV chain saw
There should be two screws on the carb an air and fuel adjustment I always start by going all the way in then 3 full turns out and then work it a half turn each time until its right..
Aug 12, 2014 | Garden
We need a manual to help replace the fuel line on a Poulan Deluxe Super 25
You do not need a manual; exactly like the video that follows:
No primer or second carburetor connection. Be kind to the oil pump; they are no longer available.
All fuel components are on the "Ignition, Electrical & Flywheel" print here (filter and hose are available):
http://www.ordertree.com/modelinfo/PWE/MICRO-XXV-Gas-Saw/75.MICRO-XXV-Gas-Saw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Micro Super XXV Deluxe S250?
Just like the video:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 26, 2010 | Garden
Need to remove gas tank from poulan micro xxv It's torn apart, tank is in part of body but not ''releasing'' easily and don't want to force it. Is there a trick to get it out without further damage. The...
STOP!!! Watch the video.
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Feb 25, 2010 | Poulan Garden
Hi...I have a Poulan chain saw 2000. I can not
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/1b4ef1f00fa5e65888256bfa0019583f?OpenDocument
Did you replace the hoses? It only needs a pin hole. This is older than dirt! I can say that, I have a XXV. There should be an impulse line from the crankcase to the carb somewhere, it may be bad. Crank seals may be leaking. Maybe time to spring for a pressure diagnostic by your friendly local Stihl shop. HTH
Lou
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 08, 2009 | Poulan Garden
Looking for a workshop manual for a poulan micro xxv deluxe Thank you
This is Poulan.com "POULAN-WEED-EATER" and your model number"Micro xxv"
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=MICRO XXV Gas Saw&AFID=59
HTH
Lou
Aug 04, 2009 | Garden
Poulan micro xxv wich will run for 5 mins then flood but why?
clean out the vents on your fuel cap. you may also have sawdust or dirt stuck on the diaphragm in the carburator
Feb 25, 2009 | Poulan Garden
Garden Logo
136 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
