Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
Irregualar idle on econo mode - Yamaha 2500 Watt Industrial Inverter Generator YG2800i
  • 905 Answers
Check the governor for excessive play, as well as the carburetor for a too rich (floats) or too lean (clogged jets). A quick shot of ether or unlit propane torch near the air cleaner will tell you which one it is. If runs better, then mixture is too lean.
Posted on Jun 12, 2010
What does the Green leaf button on lasso heater do?
It is called Econo Mode or green mode.....meaning that it will use less energy
Jan 14, 2017 | The Video Game Consoles & Games
Tip
How to troubleshoot the faded printout problem in laser printers?
This is due to this reason:-- A faded print image is normally the result of one of three conditions: The printer is getting low on toner, the print density is set too low, or Econo mode printing is turned on. For the last two settings, a printer self-test (typically a separate button on the printer) will show what the current settings are. If Econo mode is on, and users are complaining about how light the print is, turn it off and/or set the print density higher. If the toner is low, simply removing the cartridge and shaking it to redistribute the toner more evenly can temporarily resolve the problem until you can replace the cartridge. This will help. good luck.
on Mar 05, 2010 | Office Equipment & Supplies
What is the meaning of econo light wich lights on dushboard toyota nadia d4
FRANKLY i LIKE MY ECONO MODE BUT I LIVE IN FLORIDA WHERE THE ROADS ARE MOSTLY FLAT. THE BOTTOM LINE IS THAT IT SUPPOSE TO CUT DOWN ON FUEL AND WEAR AND TEAR ON THE VEHICLE. I HAVE A HAD A 2014 AND A 2015 EQUINOX AND ALWAYS KEPT IT IN THIS MODE. GOOD LUCK.
Feb 18, 2016 | Toyota Cars & Trucks
Great lakes balboa 2000 le wont change out of econo mode so doesnt heat up
Are there any error codes?
Is the control panel locked?
If no check your Hi Limit sensor, it is a thermal protection/overheat sensor which is the spas safety device. If that sensor is bad the spa will not operate/heat at all.
Jun 04, 2012 | Garden
Bosch shu5316uc filling fault
Test the water inlet electro valves.
May 26, 2017 | Bosch SHU5316UC Dishwasher
How does the power/econo button work on a 1993 mvp mazda van
The transmission select button varies the shift points , eg; when in 'econo' the trans will shift sooner than when in 'power' mode.
'power' will be to keep the transmission in a higher gear (engine RPMs higher = more power ).
Sep 28, 2011 | 1993 Mazda MPV
There is green light "econo"
i take it car is an auto... this means car is in economy mode rather then power mode... hope this helps cheers
Mar 04, 2011 | Volvo DL Cars & Trucks
When toyota vista 1999 econo sensor lights up,
What does mean econo light in toyota corona premio 2000?
Mar 30, 2010 | 2001 Toyota Camry
Would like to know what the Mode button is for on the remote control is a pink panel which has I feel, Cool, fan, Dry, what do these mean? also what is the Econo Cool button for? Can anybody help?
Cool is for cooling only- will cool until it reaches your specified temperature
Fan will operate the fan only
Dry will remove moisture from the air
Econo cool is usually for inverter driven compressors, it will run the compressor at a slower speed, hence using less electricity. Cooling capacity is, however, somewhat reduced.
Jun 10, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Dishwasher finis tone
  • Open door, push and hold Delicate/Econo button, then turn the dishwasher on while holding Delicate/Econo button.
  • Release Delicate/Econo button.
  • If module beeps, then end of cycle tone is on. PressDelicate/Econo button to disable tone.
  • If module doesn’t beep after button is pressed, then tone is disabled.
  • Turn off dishwasher to save selection.
Jan 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
255 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
