Question about Samsung LN32A330 32 in. LCD TV
Needing 8 amp ceramic fuse 3/4 inch long,for 50inch magnavox plasma tv.
    Problem Solver:
  • 13 Answers
Their is a place in Minnesota called Digi-Key. Check out the web sight. They have the most extensive supply of electronic components, and they allow you to order as few as one capacitor. They are good on the shipping as well.
Posted on Feb 05, 2010
  • 644 Answers
Do a search online for electronic componants somwhere like Maplins, and you should be able to order one of the store they are pretty cheap, you may have to purchase say a pack of five or ten but it'll still only come to a couple of quid, but then youll have a few spares if you have the problem again. hope this helps.
Posted on Jan 30, 2010
Avanti wet dry nano titanium ceramic silver digital flat iron 1 3/8 WD-AVCROC It was working fine then all of a sudden one day it does not have any heat, it shows 450 and then goes to 80 then shows error...
Does it still heat at all? There is a thermal fuse that trips if the iron gets too hot. The fuse can be purchased from DigiKey and others, but it is not easy to replace, and you need a multi-meter to check the fuse. I have repaired dozens of flat irons, not sure about that brand but they're all nearly the same.
Sep 20, 2013 | Avanti Nano Ceramic Silver Digital Flat...
What happens to a plasma tv when the power goes out and it won't turn back on? 50inch plasma Panasonic vieja
If you are lucky either a fuse is now bad or the event may have caused damage to the power supply board inside the TV set.
Jun 13, 2012 | Televison & Video
Need to find the ceramic fuse for my samsung 50"
Hello Dyan, Hi you can find one at any electrical or electronics shop that sells spare parts, But mind you the reason why the fuse blows in the first place, have the power supply board checked for shorts such as a shorted switching regulator. If in the event the replacement fuse blows again, there is definitely a shorted part. Have this checked by a technician.
Feb 12, 2011 | Samsung FPT5084 50 in. Plasma HDTV
Sony pfm-42b1 plasma tv goes to a flashing standby light when turned on - any ideas / info would be greatly appreciated - thanks
How many blinks do you get ???? It put itself in protect mode so the TV thinks something is wrong.
2 blinks X sus circuit board temp is too high
3 blinks y sus circuit board temp is too high
4 blinks center temp is too high
5 blinks digital 5V circuit is messed up
6 blinks means the PDP Panel board has failed
If you feel you cannot fix it or its too much money I will buy the TV off you for a part that I need for my sony pfm-42b Please email me at joekeniston@gmail.com and we can discuss this in more detail
Thanks
Jan 01, 2010 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Can a cooling fan be fiited to my 50inch philips plasma tv
yes to your ? i asume you have had the back off of this tv...there are 6-7 modules inside. the power supply is where you need to focus some attention. and yes plasma sets do overheat.try to find a way to attach 2 120mm fans to the heatsinks. then try to find a 12 volt source with a volt meter. attach the fans to that source and you are good to go. be carefull not to short or overload the power supply. or you will be spending 3-4 hundo for a new 1... good luck..
Nov 23, 2009 | Cars & Trucks
Need a T5H250V Ceramic fuse
693-0001.2511 order this part from mouser or allied, who ever you know that has time delay fuses 5x20mm 5 Amp 250V
Jun 09, 2009 | Philips Televison & Video
Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Samsung LN32A330 32 in. LCD TV Logo
214 people viewed this question
Jerry Greenberg
Jerry Greenberg
