Question about Car Audio & Video
I need to find the speaker wires for my 2005 toyota tundra. What are their colors?
  • 6,674 Answers
Left front is - pink (+) , and purple (-)
right front is- light green (+), and blue (-)
left rear- black (+), and yellow (-)
right rear- red (+), and white (-)
Posted on Jan 30, 2010
Plug gap 05 Toyota 4.7?
2005 Tundra spark plug confusion - Tundra Solutions
www.tundrasolutions.com/...tundra/187079-2005-tundra-spark-plug-con...
Mar 20, 2010 - 9 posts - ‎6 authors I have a 2005 DC 4x4 4.7 which is due for spark plugs. I read about ... The spark plug gap spec for the 4.7L 2UZFE is .032. The V6, IIRC, is .044 ...
Oct 24, 2015 | Toyota Cars & Trucks
Car Stereo Speaker Wiring Colors for a 2001 toyota Solara
Radio Battery Constant 12v+ Wire: Blue/Yellow
Radio Accessory Switched 12v+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Stereo Antenna Trigger Wire: Black/Red
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 17, 2013 | Toyota Cars & Trucks
Have a 2000 toyota tundra; when taking off gas tank, tank fell and pulled color wires from 5 pin connector on fuel pump. help to rewire. the connector is number 1, 2, 3, 5,4 but the wires are different...
A $20 service manual should include wiring diagrams which will show you color codes. When you buy a manual, make sure it has diagrams. murf427
Aug 30, 2012 | 2000 Toyota Tundra
I have a 2005 toyota tundra with rear parking sensor that stopped working any trouble shooting ideas?
check the fuse for that circuit.there is a beeper under the dash as well.put a test light on it and see if it flashes,that means the beeper is dead.remove the switch if there is one that turns it off and jumper across it,and check the circuit from the shifter wiring to it,and also the reverse lights,they may have it wired to the reverse lights.
Apr 26, 2010 | 2004 Toyota Tundra
Need car stereo color codes for 1996 toyota avalon xls v6
Check this for 1996 Toyota Avalon Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope helps (remember to rate and comment this free answeer).
Jan 06, 2010 | 1996 Toyota Avalon
Which is positive on wiring speaker on driver side on a toyota tundra 2007 what color ? blue or pink
the best way to find this out is to ask your local dealer or simply (or not) look at your wiring harness behind you deck (head unit) look for that particular wire and follow it back this should solve this
Sep 26, 2009 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
No power after new battery on 2005 Tundra
was the battery fully charged before installing it ? if it ran good before you installed the battery then it has to be your new battery at fault ?? unless i missed something here .. did you clean all posts inside the battery cables ? holler if you need more
Apr 25, 2009 | 2006 Toyota Tundra
Toyota Tundra 2005. ABS, Airbag, Tire & cruise dash lights flash
how do you turn the maintenance light off after making oil change?
Mar 09, 2009 | 2006 Toyota Tundra
Auto speaker wire diagram
FYI - I just took our 2004 Sequoia in because of speaker rattle coming from the front door speakers. Before I could tell them the problem, they guessed what it was. They see loads of Sequoias and Tundras with JBL systems due to the front door 8in speaker, basically, coming apart. His suggestion was to replace only the bottom 8in speaker, because the top tweeters usually are in good working condition. There is a minimal failure rate on the tweeters.
Feb 24, 2009 | 2004 Toyota Sequoia
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
