What's wrong with my computer
First time post. I have windows xp, and not really experienced in computers <_<
The computer is having trouble booting up at the start, symptoms include red dotted lines, and blue streaks across the screen vertically. When i get to the Windows logo picture where it loads. it starts freezing and then the screen goes blank suddenly turning the monitor off, yet the computer is still on. I'm able to run the computer through safe mode, but that's as far as i can get. Could this be a graphics card problem? Please help!!!!! -_-
Yes. You have a very sick VGA card in your computer. Get it replaced. The reason it runs okay in safe mode is because full potent driver and graphics don't load in safe mode to aggravate the card's illness. When the driver fully loads in normal mode, the card freaks out.
Good luck
Posted on Feb 18, 2008
How to get to safe modem?
Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode- If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen
Jan 14, 2012 | Compaq Armada M700 Notebook
Tip
How to repair Windows XP Master Boot Record (MBR) From time to time you will...
From time to time you will need a message on your computer when boot that states that your Operating System was not detected or that your primary hard drive was not found. When these messages come up alot of people think that there hard drive had fail. However alot of times it is just because the Master Boot Record on the hard drive got corrpted so the data on the drive can not be read properly. This also is the cause of the flash cursor that people will see from time to time.
Note in these cases you will always want to run a hard drive test before the reinstall of Windows as a drive failure could have caused the problem but run through the below step will alot of times show that the drive is fine.
The steps below will take you repairing the MBR on your har drive. Note to go through this process you will need your Windows XP OS CD.
1. The first thing you will need to do is boot your computer off your Windows XP OS CD. To do this you will need to go into your BIOS and change the boot order to have your ROM drive set as the first boot device. Note some OEM computers have a boot menu set to a hot key like F12. This option sould let you boot from the ROM drive without having to go into the BIOS.
2. After you have selected to boot you computer from the ROM drive with the Windows XP OS CD in the drive you will seee a message that states "press any key". You will need to press any key on your keyboard to have the computer boot off the Window XP OS CD.
3. After the setup loads you will want to select "R" to run the Windows XP Recovery Console
4. After the Windows Recovery Console loads you willl need to type the number that refers to the drive that you are wanting to repair. Note in most cases you will type "1" then press enter. Then you need to enter the Administrator password for the system. If you do not know it or does not work then at this point you will need to look at backing up for files with another computer and doing a full reinstall of Windows on the hard drive.
5. After you are able to enter the Administrator password you will be at a prompt here is where you will type "fixmbr". This will repair the damaged MBR. Inaddition will may want to run "fix boot" this will fix any issues with the boot sector.
Note if you still have trouble getting the system to boot properly after running through these steps you will want to do a backup of your files and do a full reinstall of Windows. Also run any hard drive tests to make sure there is not anything wrong with the hard drive.
on Dec 06, 2010 | Computers & Internet
Tip
Speed Up Windows XP Boot and Shutdown Times
This guide will show you how to shorten the time it takes for your desktop to appear when you turn your computer, and make it shut down faster as well. Here are a few tips to get you right to your desktop as quickly as possible after startup.
To speed up Windows XP shutdown times:
Turn off services that you don’t need. If you want XP to shutdown faster, you need to have less services running for it to shutdown. Disable any unneeded services.
Don’t clear virtual memory at shutdown. Clearing the page file can provide more security, but that comes at the expense of speed. I don’t really care if someone can look at my page file. If you are more concerned with the shutdown speed, then you will want to disable this option in the registry. You will need to locate the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management registry key and change the ClearPageFileAtShutdown to 0.
To speed up Windows XP Startup times:
Waiting for your computer to boot can be a painful process. Though Microsoft has taken steps to speed up the boot process, it still can be improved. Here a few suggestions you can follow to speed up your Windows XP boot time.
Boot Defrag. If your boot files are closer together it will take less time for your hard drive to seek the files, therefore giving you a faster boot time. This was enabled by default on my machine, but you will want to make sure you have the option enabled in the registry. In HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction
You will want to set “enable” to “Y”.
Keep the registry clean. Windows registry can be a disaster. When programs install they will create registry keys. When you uninstall the program it will leave behind useless registry keys. The solution is to use a good, reliable, registry cleaner. Be careful in which one you choose though because a bad cleaner could really screw up your system. My favorite choice is CClceaner, which will also rid your machine of some spyware and temporary internet files. You can download it here.
Change BIOS Settings. The computer has to go through the BIOS before actually touching Windows. Changing a few settings can decrease the time it takes to actually get to the Windows XP boot screen. First you will want to run a Quick POST (power on self test) if your bios has this option. Secondly you will want to disable booting from a floppy (especially slow), cd, usb. If the BIOS only has to look for the hard drive it will go much faster. You will want to remember that you changed this setting though, incase you have to boot from one of these devices for troubleshooting. The last option is to turn off Boot Delay if you BIOS has this available.
01011010 G.I.G hacker 0100101
www.gighacker.blogspot.com
on Feb 14, 2010 | Computers & Internet
How can i remove windows 7 starter and install windows xp
Boot to you bios and make sure you can boot off your dvd rom first. boot off you win xp disk and follow the instructions.
First locate drivers that are compatible with your computer and win xp.
Apr 06, 2010 | Acer Aspire One PC Notebook
Hello: I have a computer running Windows XP Media Edition SP2. Several weeks ago, I started experiencing boot up problems with my computer. It stops booting in normal mode. It will boot in safe mode. When...
It looks like you installed the wrong drivers for your motherboard.  It can cause a Blue Screen Of Death.  Also how many hard-drives do you have in that computer?  IDE?  Are the jumpers set to CS?  I find that CS causes problems.  If you have 2 devices on a ribbon cable make one master w non ATA   and the second device as slave.  Also the boot.ini could be confused.  Is the boot.ini on the wrong hard-drive   Did you accidentally put 2 operating systems on the same computer?  lots of things could have caused this.
Nov 09, 2009 | Microsoft Windows XP Professional
Acer Power FH will not boot Windows XP Pro
Well your explanation was clear but your should've not ruled out the hardware issue. if both computer suffered the same problem at the same time the problem could be within the Desktop itself. I have experienced the same problem with my HP when I move to my new house after 5 years. What happend is that during transportation the vibration lossened up the parts inside your computer. So what I did was I reseated all the parts inside the desktop and reinstalled Windows XP. Till now I have never had any problems yet.
Mar 26, 2009 | Acer Power FH PC Desktop
I just installed xp pro and it keeps freezing
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Boot volume err
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Oct 18, 2008 | Computers & Internet
Xp boots and hang up on blank screen
Insert the original Windows XP "System Restore" CD-ROM,
and tell your computer to "boot" from it.
Does it boot, and get to a screen that asks you "do you really want to ...", or does it stop at a "blank" screen?
If it "stops", you have a "hardware" problem.
If it "asks", then either:
* your disk-drive has failed, or is about to fail,
* your installed copy of Windows is messed-up, and it cannot complete the "boot" process.
Take your computer to a computer-store, for more trouble-shooting.
Aug 28, 2008 | Computers & Internet
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
