Question about Kenmore Elite 45986 Front Load Washer
Our Kemore Elite washer keeps stoping and displaying an error message of f11. We have to unplug it, or sometimes we can push a bunch of random buttons and that can unstick it! Its very frustrating......any ideas?
1. Unplug washer or disconnect from power.
2. Check wire harness between drive motor and MCU. Between MCU and CCU. Check the motor and do a continuity test.
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
6. Replace the MCU board.
Posted on Jan 31, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    F11 code flashing-washer stops
    hi!!!!
    try to unplug it end then check the control timer if it is broken !!!!
    or open it if you know and fix it may be the spring that pull back the pause botton
    might be broken go check it?
    Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
    I have a kemore Elite HE3 with a F11 code. It will restart and run for another min or so. I have checked the wires and connections
    F/11 Serial Communication Error
    Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    • Check the Drive system for any worn or failed components
    • Check MCU
    • Check CCU
    • Check Motor
    Jan 09, 2010 | Kenmore Elite 45986 Front Load Washer
    What does the F11 error code on my Kenmore Elite He 3t mean?
    "F11" is a serial communications error. The following link explains the possible causes and how to troubleshoot:
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    First, attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). In many cases, this is all that is required in order to correct momentary glitches with the unit. If the error code reappears, follow the advice provided in the link. In the majority of the cases, I've experienced, it was the CCU that caused the problem.
    If you have questions, or require additional assistance, please let me know. I hope this helps you.
    Jan 22, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite H3 error code F11
    F11 is a serial communication error. It is recomended to check connections from the motor control unit to the ccu. We are looking for the blue wires that carry info from component to component. The ccu is on top under the cover positioned in back for older machines and front right for new machines. The mcu, motor control unit is behind the kick panel below the door and is front left usually.Again we want to unplug check for dark or crusty connections if not to carefully reseat the connection and not only the blue serial wires but power as well. Remember to first unplug the machine and while you work the machine can reset, 30 minutes is typical.
    Sep 08, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite top load washer
    error code with this? f11 or f22 are control board related commucation errors.
    Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
    Random electrical problems, sometimes it works beautifully, sometimes not!
    F11 = Communication between the Central Control Unit (CCU) and the
    1. Unplug washer or disconnect power.
    2. Check wire harness connections to the MCU, the motor, and
    3. Check the drive system for any worn or failed components.
    4. Plug in washer or reconnect power.
    5. Verify CCU operation by running a Diagnostic test or any
    cycle.
    6. Check the MCU by looking for operations of the drive motor.
    7. Check the drive motor for powered rotations.
    8. Check that the serial harness at the MCU is not mounted
    upside down. The wires should be to the left when facing the
    MCU connectors.
    FDL=
    A Door Lock Error occurs if the door cannot be locked. It will try to lock
    it six times before displaying the error code.
    Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
    porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
    ■ Door lock mechanism is broken or removed from door.
    ■ Door switch/lock unit failure.
    2. Check door switch/lock unit.
    3. Check the wire harness connections to the door
    switch/lock unit and Central Control Unit (CCU).
    Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Kemore elite 21082
    It certainly does sound like the main control, this is the most common part (electronically speaking) also there is the display board(s) directly behind the control panel. This PC relays user inputs to CCU (located on top of washer ---middle rear). I havent replaced a faulty display board yet out of the 50+ ive serviced. Doesnt mean its not bad. If you have any questions feel free....
    Nov 13, 2007 | Kenmore Elite 21082
    Kitchen aide khws02rmt0 washer
    random issues with bad solder joints on the boards ,
    open the top of unit , reseat all the connectors on the control unit.
    start washer ,
    , push up gently on the center black wired connectors . system should start and run fine as long as you hold it up. normal issue is that the solder connections to the relays need to be resoldered due to crack around the leads.causing random issues
    german manufacture board
    Oct 29, 2007 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    169 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
