Question about Apple iPod nano
Unlock ipod nano. My ipod nano is locked and controls don't work.
Press the enter and up at the same time for as long as it takes around 10 or so secends
Posted on Jan 30, 2010
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Jul 25, 2013 | Apple iPod Audio Players & Recorders
Unlock
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
A1199 unlock code
Jul 08, 2013 | Apple iPod nano
I forgot the pass word to my ipod nano
the best way to unlock the iPod when the screen lock code was forgotten is to connect it to your computer and view it in My Computer. Go to folders, make sure you can view hidden files then go to ipod control click device then delete the file named _locked. unplugged ur ipod and its unlocked,
Mar 10, 2010 | Apple iPod nano
4 gb nano locked and i forgot the combination
Ipod Lock
You can unlock iPod in one of two ways:
1...Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
2...Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can’t unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Important: Apple representatives cannot unlock an iPod if you forget your combination.
If you can’t unlock your iPod and you don’t have access to the primary computer, your only option is to restore the iPod, which will erase all music and data.
Good Luck,
I hope this helps
Nov 10, 2009 | Apple iPod nano
My ipod nano 4th generation wont unlock
Reconnect your iPod to the Primary Computer where you set up the iPod originally. This will unlock the iPod and allow you to change the lock code.
Peter
Aug 15, 2009 | Apple iPod nano
My ipod is locked it says enter code and my cousin messed with it
When you lock an iPod nano that is not connected to a computer, you must enter a combination to unlock and use it. ... . You can unlock your iPod nano in two ways ... Connect iPod nano to the primary computer you use it with, and iPod nano automatically unlocks . Note: If you try these solutions and you still can’t unlock iPod nano , you can restore iPod nano.
Jul 08, 2009 | Apple iPod nano
Ipod nano
Apple iPod is Locked
There is only one way - and it will erase all your songs (applies to most models, not just Nano):
If you lock your iPod nano screen and can’t unlock it
Normally, if you can connect your iPod nano to the computer it is authorized to work with, your iPod nano automatically unlocks. If the computer authorized to work with your iPod nano is unavailable, you can connect iPod nano to another computer and use iPod Updater to restore your iPod software. See the next section for more information.
If you want to change the screen lock combination and you can’t remember the current combination, you must restore the iPod software, and then set a new combination.
Updating and Restoring iPod Software
You can use iPod Updater to update or restore your iPod software. Apple periodically
updates iPod software to improve performance or add features. It is recommended that
you update your iPod nano to use the latest software. You can also restore the software,
which puts iPod nano back in its original state.
- If you choose to update, the software is updated, but your settings and songs are not
affected.
- If you choose to restore, all data is erased from your iPod nano, including songs, files,
contacts, photos, calendar information, and any other data. All iPod nano settings are
restored to their original state.
To update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
-Tha Mp3 Doctor
Nov 10, 2008 | Apple iPod nano
Unlocking my ipod nano
There is only one way - and it will erase all your songs:
information.
combination.
â If you choose to update, the software is updated, but your settings and songs are not
affected.
â If you choose to restore, all data is erased from your iPod nano, including songs, files,
the iPod update.
opens.
-Tha Mp3 Doctor
May 28, 2008 | Apple iPod nano
Apple iPod nano Logo
142 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
