Question about IBM ThinkPad T42 Notebook
Spilled Liquid (milk) on IBM T42 Thinkpad's touch cursor and controls. Controls now don't work. The cursor works but the right and left click don't. Any ideas how to solve? I took it apart and didn't see any obivous stains or residue. I don't know how to evaluate any contact point contamination. (I don't even see where they are.) Jim
  • 706 Answers
Hi Jim,
Not sure I can tell you anything you don't already know or want to hear but the first thing I would do is flip the laptop over so any moisture from the spill will seep out of the keyboard etc... The problem being that if the laptop was powered up when the spill occurred, there is no way of knowing where that spill ended up or more importantly...what damage it may have caused... By flipping it upside down.. any residual fluid may drain out and you may get lucky and everything come back to life but the downside is that the fluid could conceivably caused a short someplace on the circuitry beneath the keyboard ... ( hopefully that is not the case) but there is always that possibility... If the only thing that is not working is the right and left command buttons... then you may be able to bypass them with an external mouse... With the power shut off to the laptop... try cleaning that area with alcohol and let air dry for a while... you may have residue beneath the two keys that are causing them to stick or always be on /off so pressing them has no effect... Not sure any of this will help you but it may give you some ideas of what to try.. Good Luck...
Posted on Jan 30, 2010
Where can I get a user manual for lenovo T42
From Lenovo Support,
http://support.lenovo.com/en_US/guides-and-manuals/default.page?
Under the white - Guides and Manuals heading in the red banner, go down to - User's guide, and left-click on it.
To the right of -
User Guides (Click 'Learn More' to download) - Thinkpad,
click on the blue Learn More
In the chart on the next page scroll down to T42, T42p in the left column.
Go to the right, and under the Windows XP heading click on -
Download in blue.
On this page scroll down to -
(English) Access IBM for Windows 2000/ XP
(1rth52us.exe / 23.5MB )
Go to the right, and under the Download heading click on the black Down Arrow.
A small window will come up on the right. Click on Save File.
A small download window will come up on the left.
Allow the file to fully download, then DOUBLE-click on it.
Regards,
joecoolvette
Sep 28, 2012 | Lenovo ThinkPad T42 Notebook
Page up button not working
Unfortunately it sounds like you're keyboard is malfunctioning and the only permanent fix is to replace the keyboard. In the mean time, since you are unable to do so, I would suggest using the touch pad to manipulate the scroll bar for the faster scrolling. For more control you could use a USB mouse with the laptop which would give you a scroll wheel. (I personally use a Wireless Mouse with my laptop because I find touch pads don't react they way I would like my mouse to use)
Nov 29, 2011 | IBM ThinkPad Computers & Internet
My touchpad buttons don't work IBM T42 laptop
In this case you probably disabled it by mistake ..and you need to enable it again ..Go to control panel ..and locate the touch pad..and see if it needs enabling . If this will not work ..you have to download the driver for the touch pad..and reinstall it ..or ..if the driver is still in the system it is enough to get to control panel ..add hardware ..and run the add new hardware wizard..This will search for hardware and show the ones which are not installed or ..if no one is present ..select already added and look for the pad..
Or ..I would option for getting into device manager..(right click on computer ..select properties../hardware /device manager..or direct device manager for win7 ..)
in the device manager select the touch pad..and click right on it ..and select update driver..This will start the wizard and install the missing driver if it is still in the system ..If it isn't you will have to install it manually after you download it from the support site ..or from the disk .
Nov 24, 2011 | IBM ThinkPad T42 Notebook
I have an IBM ThinkPad T42 and until a few minutes ago my touch pad was working with no problems. I installed a wireless mouse and that works fine. But I cannot control the cursor with the touch pad or red...
Try going to Start>Control Panel>Printer and other Hardware and look for mouse pad or something like that. I think the problem is that you can only use either the mouse pad or the mouse, can't use them both at the same time.
Oct 15, 2009 | IBM ThinkPad T42 Notebook
I can not hear sound from ibm thinkpad t42
If you are using windows XP, click Start, right click My Computer, Properties, Hardware, Device Manager.
Check if your Sound device is installed. If not, download and install the driver at http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
enter your laptop model found on the bottom.
Oct 14, 2009 | IBM ThinkPad T42 Notebook
IBM thinkpad t42 boot up problem.
The most common reason is memory.
First, try to reseat (remove and reinsert).
If still a problem, test one module at a time.
Hope this helps.
Aug 17, 2009 | IBM ThinkPad T42 Notebook
Ibm thinkpad y42
You will find under window graphic controls you can no longer Print screen like when we used the LPT-1 ports.
so a work around is to copy and paste to word, word pad, publisher, almost anything that has a cursor blinking.
any way here goes, select (highlight) the area you want to print and if you want the whole page under edit click on select all....then put you arrow (cursor) on the blue part, right click and choose copy.
then open word, word pad and right click again and choose paste. then send that page to the ole printer...and viola...you done did dodit....
Hope this works for you my friend, good luck, please leave rating. thank you kindly
Apr 27, 2009 | Computers & Internet
Ibm thinkpad t42 switch for wireless network
The T42 has a bulit-in wireless network adapter and a LAN network card. T42s most likely have an Intel wireless card or less likely a Cisco wireless card.
Your wireless network adapter may have been disabled in the BIOS
and/or
The drivers for the wireless network controller has not been installed.
To check the network adapter go to the Control Panel, Click on System, click on Hardware Tab then Device Manager. Then scroll down and click on Network adapters. If you don't see your network controller or you see a yellow ? against Other devices for the Network controller. Then either it has been disabled and/or the driver was not installed.
To get the driver for the network controller you need to dowload it from the IBM/Lenovo WEB site their support/download page from a computer that has Internet access. Make sure you select your laptop model and the driver for your Windows version.
Install the driver and you then need to configure the wireless adapter to suit your wireless router settings before you can access the Internet.
Jan 23, 2009 | IBM ThinkPad T42 Notebook
S-Video displays desktop but doesnt dislay media player video
Right Click on the desktop, go to properties -> Settings -> Advanced -> Troubleshoot, then
reduce the hardware acceleration to "None".
Dec 14, 2008 | IBM ThinkPad T42 Notebook
IBM T42 LAPTOP
If there is an icon in the taskbar refereing to your wireless connection, right click it then properties, then connect. You can also get to it through control panel> internet conenctions and then click on your wireless connection and click enable.
Feb 07, 2007 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 Notebook Logo
152 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
