Question about Lexmark X1150 All-In-One InkJet Printer
I am trying to print a document however nothing is printing. I have placed new ink cartridges within and the printer takes in the paper and the noise suggests it is printing and recognising the text within the document, but comes out blank, please help
  • Lou H
    Lou H May 11, 2010
    When you replaced the cartridges did you calibrate them?
  • 706 Answers
First thing I always check is the last thing that I did... so ..i fi t worked prior to replacing the ink cartridge/s ..and you replaced them,... did you: peel off the protective tape from the cartridge before installing them? Did you install them correctly.. meaning are they properly seating into the printer and making proper electrical contact with the printer connector? Lastly, are you sure you have the correct ink cartridges installed? After verifying all those things, try printing a test page by going to the control panel..then printers... then select that printer shown with the right mouse button ... and properties in the popup menu for that printer.. it should allow you to 'print a test page'... you may also have a loose cable ( usb or parallel connector ) not seated right between the priinter and the computer... Hopefully, one of the suggestions listed above will get you going... Good Luck..
Posted on Jan 30, 2010
Printer ink cartridges full but nothing comes on the paper
Try those solution:
- Clean the head within the printer maintenance mode.
- If you filled the cartridges by yourself, make sure that you empty the cartridges of air after filling it with ink!
Mar 18, 2012 | Office Equipment & Supplies
Making noise like its printing but nothing comes out on paper
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 4800 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Jan 21, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
My P2015 "attention" light is
Hve you tried to replace the ink cartridge or take it out and then place it back in? Also you may want to power cycle the printer with the cartridges out. Take out the ink cartridges, turn the power off with them out, unplug the power cord from the back once all noise has stopped and the printer has shut off. Leave it unplugged for about 3 minutes or so and then plug it back in, turn the power on and allow for the printer to recognize that the cartridges are not in place. Now you will need to put the cartridges back in and this should allow for the printer to now recognize the ink being installed, which is where this error message is stemming from. Please reply once the above steps have been taken and advise on the outcome. We will take further steps if needed.
Nov 13, 2010 | HP LaserJet P2015 Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
The machine prints documents when using the print
When not used for any length of time, ink jet printer print heads will clog with dry ink. You can try to manually clean the printhead with a cloth moistened with water or maybe alcohol until you get some ink on the cloth. Then reinstall and run cleaning cycle. If unsuccessful, new cartridges are needed.
Aug 03, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer will print pictures, but won't print documents.
Sometimes this happens because the ink dries in the print head. If multiple cleaning doesn't improve it you can try cleaning the print head itself with alcohol or an electronic spay can type cleaner. This should fix the problem for you. Also resetting the cartridges in the slots sometimes improves the ink flow.
Mar 29, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
HP business inkjet 1100
This very simple solution works on my Business Inkjet 1100.
1) Turn the printer off, then back on, to clear the error.
2) Set your computer's clock back to a date prior to the cartridge expiry date.
3) Print something, (any documents will do).
4) Set your computer's clock forward to the correct date and the printer should still print, and ignore the expired cartridges.
My 1100 re-checks the cartridges and dates occasionally, but not frequently (it has been about two months between checks) so you might need to repeat this process every two months or so until you have used up your expired cartridges.
This solution is much easier than dismantling the printer and changing/removing wires!
Sep 10, 2008 | HP Business Inkjet 1100dtn Printer
Balck ink not working
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Mar 16, 2007 | Canon S 330 InkJet Printer
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
82 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
