Question about Mitsubishi WS-55905 55" Rear Projection Television
Green edge around images (outline)
Sometimes thin and at times widens
sometimes flashes the green outline
model ws55905
My 2002 sony wide screen projection tv has menu and pictures when turned on first thing in the morning?
Posted on Jan 30, 2010
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
The picture looks like a bowtie and red blue and
TURN YOUR COLOR OFF.IF YOU SEE THE RED,BLUE AND GREEN AROUND THE EDGES EX.SOMEONES FACE YOU CONVERGANTS IS OUT NEEDS RE LINEMENT.
Apr 24, 2010 | RCA Televison & Video
I have a 61'' Panasonic tv that is showing green and red outlines around the figures on the screen. It originally started as just green outlines. Any ideas on what the problem is would be great. Thanks
The convergence is off. The convergence is basically the assimilation of the image on the screen from the three "guns" behind the screen. There should be a menu option to align the convergence in the image portion of the menu. If this does not fix the issue, then your convergence chip might be on it's last leg.
Oct 23, 2009 | Panasonic Televison & Video
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Green outline/shadow on dark images or backgrounds
LVDS Cable is corroded - This is the cable the provides video from the TV Video Process board to the LCD Panels Timing Control Board.
Honestly, if you can take the TV back do so. If not, Service it using the manufacturer warranty
Jun 24, 2009 | Vizio Televison & Video
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Mitsubishi WS-55905 55" Rear Projection Television Logo
185 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
