Question about HP Pavilion a305w (DM181AR) PC Desktop
I upgraded my ram from 256mb ram to 512 mb ram on my hp pavilion a305w. it wont boot up, nothing on the monitor and i keep hearing a beep. i dont know whats wrong. please help.
  • 6 more comments
  • aneubanks Jan 30, 2010
    I put the original 256 mb ram back in and still not booting up, blank screen and the beeping continues. there was alot of dust inside the cpu. this is the first time i opened it. could that have something to do with it?
    i upgraded from 256 mb ram to 512 mb ram on my hp pavilion a305w. my pc wont boot up, the monitor is blank and there's is this constant beep that wont stop. i took out the 512 mb ram and put back the 256 mb ram. same thing, wont boot up, monitor is blank and the beeping continues. i have to add that there was lots of dust inside the cpu as this is the very first time I opened it. please help
    I only added one 512mb ram. i took out the 256 mb ram and put the 512 in. when that didnt work, i put back the 256 and still wont boot up, keep hearing this beeping. there was also alot of dust inside the cpu.
    this is sounding complicated, so many wires. i touched the metal part of the cpu before changing the memory. i hope i didnt hurt the motherboard.
    i upgraded 256 mb ram with 1 512 mb ram in my hp pavilion a305w desktop. now the pc will not boot up, the monitor is blank, and there is this constant beeping. i was told that i might have damaged the motherboard (hope not). i was also told the constant beeping is the memory not being properly inserted. there was also alot of dust inside the cpu which i cleared out. i dont know what else to do as i tried to but back the original memory and still get this constant beeping. any suggestions would be appreciated.
  • aneubanks Jan 31, 2010
    its working now!!!! thank you!!!!!!
    its working now!!!!! i didnt push the memory in hard enough. thank you!!!!
    yes, thank you for all your help. my pc is back up and running smoothly!!!
  • 542 Answers
If you have added one more 256MB, then need to check and insert /press memory module properly. also try to insert the memory module into other free slots.
If you have upgraded the memory module with 256 to 512, then the memory module may having the issue.
Note: Clean the slot first and reinsert will some time works.
Revert back for more assistance.
Posted on Jan 30, 2010
  • 4 more comments
  • Rajesh Pai
    Rajesh Pai Jan 30, 2010
    Continuous beep indiactes the RAM module was not inserted properly. First you remove the dust from memory slots using brush or vacumme cleaner and then insert the RAM will solve your problem.
  • Rajesh Pai
    I am very much sure that the beep indicates the dust accumulated on the memory slot or memory slot is having the problem. Clean the memory slot using vacume cleaner and insert the RAM will solve your problem.
    2nd Option: Insert the RAM on other memory slots.
  • Rajesh Pai
    Also clean the RAM pins by using eraser.
  • Rajesh Pai
    Also check whether the display card has been properly inserted. While cleaning the CPU, the display card may came out from PCI slots.
  • Rajesh Pai
    Rajesh Pai Jan 31, 2010
    I very happy, if you give your valuable feedback and rating on the same.
  • Rajesh Pai
    You have forgotten to give your valuable feedback and rating on solution provided by me.
    President:
  • 1,015 Answers
You will need to verify that the memory chip is fully seated into the bank. They are kind of difficult to install and require a fair amount of force to install. The way to tell is the plastic clips will be completely closed onto the memeory chip when fully seated. Also verify that the memory is compatible with your computer. If it is fully seated and the correct memory then the memory chip could be defective.
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512) requires the removal of the installed 256 MB DIMM Speed supported PC2700 MB/sec (messages at PC2100) Type 184 pin, DDR SDRAM DIMM slots Two
So if your memory installed is more that PC2700 then it will not work. Let me know if you have any questions.
  • muebe Jan 30, 2010
    Could be. Did you make sure that you were grounded before touching the motherboard? If you had static electricity stored in your body it could have discharged onto the board and damaged it when you touched it. Always use a wrist gounding cable or touch the chassi of the computer to release any static before touching computer components. I would use a can of compressed air to clear out all the dust in the computer housing. Then check that the memory is seated properly again. Check for any disconnected cables that might have pulled out when you installed the memory. You might need to try and clear BIOS CMOS by using the clear CMOS jumper that is located on the motherboard near the battery(watch battery). Once you locate this jumper you will need to pull it off and re-install it on the opposite side pin for a few seconds then put it back. If you cannot locate the jumper then you can remove the watch battery for about 10 seconds the re-install it. That should do the job. Then try booting up the computer and see if it comes back up. If not the motherboard could have been damaged from static discharge. Also check that the screws holding the motherboard to the chassi are all tight. The motherboard uses these screws as a ground and they might be loose. Let me know what you find.
    Did you try the "clear CMOS" jumper on the board or removing the battery for 10 seconds and then re-installing it? This may get the computer working again with the old memory installed.
Upgraded ram 1gb wont boot hp 510 mobo 30C4
If you added another 512Mb RAM to increase the RAM to 1Gb then the new 512Mb memory stick could be incompatible with the original 512Mb or it could be faulty.
Use RAM that is same make and speed as the original RAM.
Remove both RAM and just insert the new 512Mb into your laptop and see if the laptop boots up, if not then the RAM could be faulty.
Mar 02, 2013 | HP 510 Notebook
Hi, Replacing my 256mb ram (1 slot) with 1Gb (2x512). The computer would not boot. Removing 1x512 memory the computer works fine. I put my old 256Mb back with the 512 Mb and the system only reported 256Mb....
Is the speed of the RAM the same mixing PC 133 and PC100 ram can cause problems working together. Also it sounds as if your board will only upgrade to a maximum of 512 MB total.
Aug 15, 2009 | AOpen Computers & Internet
I wanted to upgrade the memory on my pavilion zt1130 notebook from 256mb so I purchased to 512mb memory cards and replace the resident memroy under the keyboard. It runs faster but as soon as I put the...
According to Hp website your computer will handle two 512 Mb RAM chips. Make sure they are PC133. If computer will not boot with both inserted properly, one of them is bad. Put one in slot 1 and none in slot 2 and see if it boots. Then switch the chips put the extra chip in slot 1 and none in slot 2. See if it boots. This way you can troubleshoot a possible bad chip.
Aug 15, 2009 | Office Equipment & Supplies
E machine T1150 wont start up
Make sure you have the memory installed correctly. Those beep codes identify it as bad memory. Try the old RAM.
Good luck with this.
Mar 19, 2009 | E-Machines T6420 PC Desktop
Installed memory cpu is making a loun beep and wont boot up
Ram is not supported or installed incorrectly, try readjusting it, then reset the CMOS and try again. If ti doesn't work after the readjust make sure that the ram speed etc is supported by your motherboard.
Dec 22, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Installed a new memory now computer won't boot up.
u just bought the wrong type of memory take the chip out of ur pc to best buy or a good computer store to help u buy the correct memory
Nov 24, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Wont boot up
You could be using the wrong type of memory. Check your mobo specs to see what your mobo is compatible with.
Oct 23, 2008 | ASUS P5RD1-VM Motherboard
HP PAVILION a305w
try getting into the bios and setting it to boot normally, turn off fast booting if its an option thats on, also, set your CD drive as the first boot devioce, then hard drive. Save and reboot, have CD in drive and just start hitting the F10 key as soon as it starts up, usually you hear a Beep when it detects that you are hitting the key for the boot options. HP pavilions where made to start and skip through the Post Process quickly to limit waitnig time, of course this sux when you want to boot from a cd.
You could try remove ing the BIOS Battery off the board and unplugging the system, wait a minute for it to discharge and put it back in, power it up and see if it lets you boot from CD.
Your bassically resetting the BIOS to factory defaults.
Also, i dont recomend buying HP Pavilions. i wokred on three seperate ones that a customer thought was a New machine ( this was back in 2001 ) but all the parts where 1995 parts, which means wghen they tried to upgrade to windows XP, XP doesnt have any generic drivers for hardware that old so nothing worked and yuo cant find any driver online that are that old.
Good luck anyway.
Feb 15, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Memory upgrade problems
Hmm if the pc takes DDR Ram , it should deffently take 512 sticks, have u tried booting the computer with just the one 512 stick ? or try putting the 256 stick in and 1 x 512 stick , test it that way with both sticks , some older computers there is a bios setting for upgrading to higher amount of memory, but in your case with DDR ram i dont think so , i mean it may be worth a shot going into bio's and load optimized defaults , press f10 to save settings, try one stick at a time after that , if still no go , there is a jumper pin on the mother board that u can move over a slot which will restet the bios, if u dont know this jumper pin or where it is, just remove the round battery on the motherboard for 30 seconds , then put it back in , try your new ram then , u will be asked to save settings on boot up , if it still dosent work the ram is either faulty or incompatible, alot of the time with Dell , HP /Compaq desktops there fussy with the type of ram they take, but if u ordered from dell it should have worked !! whats the brand name of the ram u have is it hynix? /HP this brand of ram has alot of issues with compatibility,
Nov 21, 2007 | Dell Dimension 2350 PC Desktop
HP Pavilion a305w (DM181AR) PC Desktop Logo
88 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
