Question about Radio Shack Pro-94 Scanner
I can't get any sound when the scanner stops on a frequency #
  • carolinab57 Jan 30, 2010
    The only sound is from the squelch when it's turnt back of course.I hadn't been able to get anything out of it before today.I opened it up and looked inside the wires to the speaker were attached.If the speaker were burnt out then the squelch wouldn't work,would it?Thanks
  • carolinab57 Feb 01, 2010
    Yes thank you very much
    Top Expert:
  • Radio Shack Master
  • 14,553 Answers
Since I do not know what you have or have not tried:
1. The squelch is turned down or even off?
2. If it has an earphone jack have you checked for audio that way?
3. Have you searched the RS site for tips for this problem? They have a lot of very good information there.
4. If you Google the brand/model number with "no sound" after it I think you will find this is a common problem and I remember seeing some suggestions and causes for the trouble.
Let me know as much as you can----I am here to help.
Regards, SD TECH
Posted on Jan 31, 2010
  • SD Tech
    SD Tech Jan 31, 2010
    You are able to turn the squelch down and still do not have sound; what about the headphone jack?
    The speaker could be open-----check like checking a fuse---impedance should be marked on it--4,6, 8 16 ohms etc---no reading across it means it is gone.
    The other common thing that happens is if the unit got dropped or fell over it may have caused physical damage inside the unit.
    I hope you find an open speaker--that is the most easy thing that could be wrong.
    SD TECH
  • 324 Answers
Turn the volume up and the squelch down, just to make sure that you are getting sound without a signal, if not then your speaker may be burned up or disconnected
if you get static when following above advice then try tuning to the NOAA weather radio, their frequencies are 162.400, 162.425, 162.450, 162.475, 162.500, 162.525, and 162.550 MHz respectively.
but if your hear a hum and clicking sound when your scanner stops then you are probably experiencing "Ghosting" a phenomon where the scanner is picking up electrical signatures or interference from other devices or even itself. or it could be someone literally sitting on their microphone. good luck, hope this helps.
nothing you can do about ghosting, there used to be a website that listed different radios and their known ghosts but I can't seem to find it.
Posted on Jan 30, 2010
No transmissions on Uniden Bearcat BC80XLT
Are you sure the frequencys have not changed in your area? They changed in mine recently. uou can do a search about your area freqs. Make sure antenna is in all the way, easy things, etc. here is a link to the manual if you need it. www.racingelectronics.com/files/bc80manual.pdf
Jan 19, 2015 | Uniden Radio Communications
I have entered a few frequencies into my scanner and now i am trying to get them to scan. I press the scan button and it will scan a channel one at a time, but i would liek for it to scan all the...
Your BC72XLT SCAN feature samples one frequency/channel at a time, but it should only stop on active frequencies. If it's stopping on inactive frequencies you may need to adjust the squelch. For more details on programming and operating your scanner you can download and print the factory manual, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
Bill B.
Listening in since the 60's
Apr 20, 2011 | Uniden BC72XLT Handheld Scanner
Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit www.RadioReference.com to view the latest on active frequencies and systems in your area.
Bill B
May 17, 2010 | Radio Shack Pro-94 Scanner
How to setup manual scanner
To manually enter a known frequency:
- Power the scanner ON.
- Press HOLD to stop scanning.
- Enter the channel number that you wish to program.
- Press FUNC then PGM (the channel number will display).
- Enter the frequency, including decimal point (e.g., 156.065).
- Press E to store the frequency in memory.
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 01, 2010 | Uniden Nascar BC-92T Scanner
I cannot figure out how to program my scanner to the fire frequency.
To program any known frequency into your BC72XLT, power the scanner ON, and then:
1. Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears.
2. Use the number keys and to enter the frequency (including the decimal point) you want to store.
3. Press E to store the frequency into the channel.
Notes:
• If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency.
• The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475.
• When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning 2 seconds after the end of a transmission before scanning proceeds to the next channel. To turn the function off or on, press Func + Dly.
• If you enter a frequency that has already been entered elsewhere, the scanner sounds an error tone and displays the channel that was duplicated. If you entered the frequency by mistake, press then enter the correct frequency. To enter the frequency anyway, press E to
accept.
4. To program the next channel in sequence, press E then repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
Jan 16, 2010 | Uniden BC72XLT Handheld Scanner
Police scanner stops on only one channel
Sounds like you don't have the correct frequencies programmed into it. For an extensive list of active frequencies and systems in your area visit
or
www.CityFreq.com
Nov 28, 2009 | Radio Shack Radio Communications
Need a free printable user manual for Bearcat scnner BC142XL
Its so easy to use you really don't need a manual for the Uniden BC142XL scanner.
Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on channel one.
Using the keypad enter the frequency you want to monitor, then push "E." Press "REVIEW" at anytime to see what frequency is programmed there. If the review button flashes 000.0000 on the LED readout display, you might be entering an invalid frequency. Refer to the list of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push "E." Push "MANUAL" to step to channel three. Repeat this process until all the (10) channels are full, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band
If this helps, please take a moment to give us a rating -- and a rating of "very helpful" would be greatly appreciated.
Sep 06, 2009 | Uniden BC-95 XLT Scanner
New to scanners - BC898T - how to search
i cant get the scanner to search all frequencies
Feb 02, 2009 | Uniden BC898T Base Scanner
Reception
Simple off-channel interference, tell the scanner to skip or lock out the frequency, unless that's how it sounds on every frequency. If it does sound like that on every frequency, you may have a busted speaker, use an external speaker instead.
Mar 23, 2008 | Radio Shack Pro-2096 Base Scanner
BC72XLT
Here is the directions to store frequencies in your scanner:
Storing Known Frequencies
Into Channels
to store.
Notes:
Operation 2 seconds after the end of a transmission before
accept.
Dean
Rollin CBs
Feb 19, 2008 | Uniden BC72XLT Handheld Scanner
Radio Shack Pro-94 Scanner Logo
41 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
