Difference between router
What is a tyte II router ? is this different than any other router
  • Jocelyn Viau
    Jocelyn Viau May 11, 2010
    Do you mean Type 2 or really "tyte"? Can you give an example or a more detailed description of what you want to know or do with such device?
    Guru:
  • 731 Answers
Type II routers are Wireless ADSL (Asynchronous Digital Subscriber Line) Routers.They are used as routers for connecting to the Internet Wi-Fi.(i.e)You may also call them as modem.Type II routers links a DSL to ISP(Internet Service Provider).You cannot change most of the Configuration of the type II routers, you allowed to change only few configurations.
Example ::
>>Cisco 3620
>>UTSTARCOM WA3002-g1
The Other Router like Cisco 1800 series /2800/ 3800/ 7600/ Catalyst 6500 Series, they are all Higher Routers, where u can configure and Program them, for connecting a LAN/WAN/MAN.
I hope is answered your question!!! Any more clarification, plz reply me!!
Thank YOU
Riz
Posted on Feb 18, 2008
Drain fluia from transalxe how many go back and what tyte 95 toyoto camry
The 1995 Toyota Camry originally came with Dextron II, but since Dextron II was introduced it has been replaced with Dextron III. You should use the Dextron III transmission fluid. It should take around 2.6 quarts of fluid in the Transmission and around .8 quarts in the Differential (4 Cylinder 5S-FE Engine).
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Oct 09, 2011 | 1995 Toyota Camry
I plug it in and there is no power the light is not on
Hi stella_bella,
I see that your D-link Router will not turn on or power up as you mentioned.
If I may ask Have you tried a different power source / Outlet?
also try ti find a different adapter with the same wattage on it and see if the Router will power ON using a different Power Adapter.
When did you notice your D-link not powering ON? was there any power surges lately, that can cause Router or Modem to get busted or damaged if ever you were either online or if the Router was turned on during the power surge.
The only thing you can basically do is try a different Power outlet or power source and a different Power Adapter of the same wattage to avoid damaging the Router more.
I hop that this helps.
Have a nice day,
mvincentc
May 08, 2011 | D-Link AirPlus DI-524 Wireless Router
My wireless is going on and off, what's the problem?
Frequent wireless disconnection can be caused by different factors such as:
• Wireless interference within the network
• Wireless settings of the Linksys ADSL gateway are still set to default
• Firmware is corrupted
NOTE: Before going through the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
To resolve intermittent wireless connection, you need to perform the following steps:
i. Reducing Wireless Interference
ii. Customizing Wireless Settings of the ADSL Gateway
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
Routing problem
The last part of the IP address has to be more than 10 apart. That is to say: if your first address is 193.156.36.90 then your second should be 193.156.36.100 or higher or 193.156.36.80 or lower. I like to go for 50 higher or lower then you are well out of the range of your main router.
May 27, 2009 | 3Com SuperStack II NETBuilder 222 Access...
When I am trying to figure the standard deviation on my BA II plus I am not getting the right answers?
s=sqr(1/(n-1) sum (x-x_ )^2  or  sqr(1/n)......
just a slight differance  but never the less differant
hope this helps
Jan 15, 2009 | Texas Instruments BA-II Plus Calculator
Bridging 2 different types of router
Yes, you can bridge two different brands of routers. It is not the router but the protocol that the router uses that makes it incompatible. But because of the way you are set up you will not have any problems with different brands. Both will use DHCP to get your IP address..
Dec 26, 2008 | Computers & Internet
No lights
hello!
Is there a computer connected directly to the router? Possible that the router do not detect any physical connection on it. if none of the number light light up it means that there might be no computer directly connected to the router .
Have you tried connecting your computer to a different port? how about using a different cable? How about a different computer? if theres a computer connected to it hardwired but still no light, try to connect your computer to the other ports of the router and check if the lights will come on. if not, try a different cable and a different computer. Possible that t could be a defective port, defective cable, defective lan card or the driver of the lan card on the pc is not properly installed that's why the pc is not detected
Aug 27, 2008 | Belkin (F5D7230-4) Router (587009)
Wired connections can't play RISK II w/wireless connections
This is because they are on differing addresses.. you may have to "Bridge" the network connections.. the Wifi is probably on 10.0.0.* and the Wired is on 192.168.0.* you need to make a "Connection" between the two so the can "See" each other. You will find how to do this in ya manual. Here is a link to help.. www.microsoft.com/technet/community/columns/cableguy/cg0102.mspx I "Googled" how to bridge wireless & wired networks router xp So if ya get stuck try a "Google" ... :)
Aug 19, 2007 | D-Link AirPlus DI-614+ Wireless Router
Computers & Internet Logo
178 people viewed this question
Alun Cox
David Payne
David Payne
