Can't install program officejet 7000 using window 7
  • 36 Answers
Download this and install it if you have the 64-bit version of windows 7. and download and install this if you have the 32-bit edition of windows 7. I hope this is what you need. If this helps please tell me, thanks and good luck!
Posted on Jan 30, 2010
  • 74 Answers
Maybe they are not compatible
Hp officejet 7000 printer cartridge bulb and power blinking
Carefully check the Header . hope it will solve your problem.
Jul 16, 2014 | HP Officejet 7000 Wide Format Printer...
Hp 7000 won't print A3 paper size
mau nanya gan,printer ane hp k7000 gak mau print a3 tlng beri info gan ?
Feb 24, 2012 | HP Officejet 7000 Wide Format Printer...
I was using HP Officejet Pro K8600 Windows xp, and now I am using Windows 7, I feel there is a proble in the installation, please advise?
check you installer if is compatible for window 7.if ever not compatible.go to HP.com to find and download a new driver..
Jul 06, 2011 | HP OfficeJet Pro K8600 Printer
I need the drive of video for Windows 7, my drive is ATI_100705R
ATI RADEON 7000 GRAPHIC SUPPORT WINDOWS 7..
it supports xp 32-bit , windows 2000
if you want to install win 7 try the HD series of ATI RADEON.. HD series of ATI SUPPORTS WIN 7.
Dec 18, 2010 | ATI RADEON 7000 PCI Graphic Card
Hi i have an hp officejet 4355 allin one printer that worked well on windows xp. i changed to windows seven and used my hp disck but cannot load the printer. how must i do it. thank you. george weber....
Hi!
The driver or software that's on your disc may not be compatible with windows 7.. According to HP website, HP has not created a driver for your printer that is compatible with windows 7.. But Windows7 has it's own driver for your printer..
Try the ff steps to install the windows 7 driver:
- frist, uninstall the program you loaded from the disc
- go to Control Panel, Look for Programs & Features or Uninstall a program.. it will load the list of all programs in your machine.. Click the entry /entries for HP Printer, then click uninstall button on top of the list..
- or you can reload the disc and it should give you the option to uninstall it..
Then, follow this for the proper installation of your printer..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01796736&lc=en&dlc=en&cc=us&os=4062&product=1138373&sw_lang=8#N1076
Hope this helps.. :D
Sep 13, 2010 | HP Officejet 4355 All-In-One InkJet...
My new computer has windows 7 and disk for set up is for xp. How do I download so compatible with
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Aug 30, 2010 | HP J3680 Officejet All In One Printer
Need to set up scanner on officejet 7110.
Connect the printer to the system and power on the printer. Start the system let it boot completely, put the CD that came with the Printer and install the drivers . From the same CD, run the setup to install the scanner software for the printer. Read cafefully the instruction on each installation wizard window that opens and follow the instructions.
However, if you are using windows 7 Operating system, just install the printer driver, go to start, All Program, Windows Scan and Fax. Lunch this and with it you can scan your document
Jan 26, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Can window 7 home premium run 7 year old hp k80?
With thanks and complements to the HP.com website
Don
A full feature software and driver package for Windows 7 is not available for your product. However, the Windows 7 operating system installed on your computer contains a basic driver solution for your product. With the basic driver, some of the advanced product features are not available. However, using the workaround procedures in this document, you can still print from a software program. You can also import and view images on a memory card, if your product has a memory card slot. Use the following instructions to install the basic driver in Windows 7, and then review the workaround procedures to use the available features for your product.
Nov 23, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Can someone advise if the Epson GT-7000 scanner which I had working in XP can be made to work in Windows 7 or is it time to throw out my faithful machine? Rodney.
I got mine working on Windows 7 (x64) by doing the following:
1. Download the Windows 7 Epson Scan driver for the Perfection 2400 from the epson site 2. Install the drivers 3. In Start Menu->All Programs->Accessories right-click Notepad and select Run as administrator 4. In Notepad File->Open and browse for the es27.inf file located in C:\Program Files (x86)\epson\escndv\es0027 5. On line 51, 54, and 57 replace PID_011B with PID_0101 6. Save the file. 7. Connect and turn on the scanner. 8. In Device Manager (Start Menu, right-click Computer, select Properties, Device Manager) right-click the scanner and select Update Driver Software->Browse my computer for driver software 9. Select the location of the modified INF file (C:\Program Files (x86)\epson\escndv\es0027 Include subfolders checked). 10. Say ok to the window that pops up and it should start installing the drivers.
In Photoshop you should then be able to import using WIA-Epson Perfection 2400 (importing with Epson Perfection 2400 causes Photoshop to freeze)
I hope that works for you :)
Stephen
Sep 28, 2009 | Epson GT 7000 Flatbed Scanner
120 people viewed this question
k24674
jasbo
jasbo
