Question about Kitchen Ranges
Have a caloric prestige series natural gas oven model #35-302251-05-0 The electric display does not work, there is power going to the display. Is there a tilt switch on this unit and if so where
SOURCE: caloric gas stove prestige series
My one spark ignitor on my stove top comes on by itself and keeps clicking till I pull the plug. It will reset itself and stay off for awhile then it will come on by itself again sooner or later. What is the problem??
Posted on Sep 30, 2008
  • 15 Answers
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Posted on Oct 07, 2008
aborcass
  • 2651 Answers
SOURCE: caloric oven does not completely light
i would replace the ignitor, although its glowing its not glowing strong enough to allow gas to release, simple repair, part numbr 31939701
Posted on Nov 23, 2008
bobsteelesp
  • 22 Answers
SOURCE: Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Posted on Sep 12, 2009
  • 1891 Answers
SOURCE: GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Posted on Dec 23, 2009
Finding the flame pilot on a caloric prestige series gas stove
There is no pilot. The igniter is in the oven cavity under the floorpan. This is a picture of the regulator and gas valve- the wire nuts at the top of the pic just left of center are on the leads that go to the igniter...
Jun 26, 2016 | Kitchen Ranges
Why won't the gas oven heat? The oven won't light and gas is not leaking when I turn the oven on.
does it have a pilot light or is it electronic ignitor . might need ignitor replaced
Jul 23, 2014 | Ovens
Please help find oven mauel
open oven doors and check behind the bottom of the doors for mod number
Nov 21, 2013 | Ovens
How to turn on self-clean
I have an older model prestige series caloric oven
Oct 01, 2012 | Fisher and Paykel Titan OS301M Electric...
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
Broiler coil is on when bake is turned on...is this normal?
On some kitchen ranges, the broiler comes on during the preheat cycle to speed up the process of warming up the oven and reduce the wait time. This is intended as an energy saving feature as well by reducing the amount gas used on a gas range and the amount of electricity with an electric range.
If the broiler comes on and STAYS on while you are baking, this is NOT normal and is probably an indicaiton that you have a problem with the Electronic Oven Control (EOC) board. This is your timer/clock assembly on the operator console. The EOC controls all the oven features.
If you have any questions, please post back and let me know. Please post your MODEL NUMBER when submitting questions, so I can determine how your range is configured. I hope this helps you.
Mar 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
Oct 18, 2009 | Ovens
Need owners manual for Caloric prestige series electric stove. self cleaning instructions
prestige cooker with built in oven is suddenly making loud noise .don't know what to do?
My caloric heritage series stove oven will not ignite.. pilot flame is on. I need parts..w here can i get them thanks.
I have a caloric prestige electric stove and the electronic ignition don't work. Does anyone have a solution for this problem?
Oct 05, 2009 | Stoves Ovens
Kitchen Ranges Logo
180 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
