Question about Frigidaire GLTR1670A Front Load Washer
Can you replace the gasket yourself? - Frigidaire GLTR1670A Front Load Washer
  • 129 Answers
YES REMOVE FRONT PANEL PUT NEW BACK IN REVERSE OF OLD REMOVAL
Posted on Jan 31, 2010
What causes water mix with engine oil
I would suspect that you have a bad (blown) head gasket. This let's the water or coolant seep through to the other side of the gasket where the oil is in your engine.
My recommendation is to replace the head gasket, well actually both since you will have it torn apart anyway, unless you don't plan on keeping the vehicle much longer.
If you don't have the expertise, tools, confidence etc. to do it yourself, I would recommend taking it to your mechanic. If you do decide to do it yourself, make sure when you scrape the old gasket material off the block and heads that you do not leave any small particles in either and don't over apply the gasket sealer when putting it back together, a thin layer will do.
There are many You Tube videos to show you how to replace them.
Nov 01, 2015 | Cars & Trucks
Changing oil pan gasket
Not a do it yourself job, unless you have done them before. Alot of work with replacing this gasket.
Nov 03, 2013 | 2006 Lincoln Navigator
Timing chain cover gasket leak
either take it to the shop or do it yourself, replace the gasket, and while your there replace the timing chain, you don;t want it to break. disater
Jun 24, 2013 | Jaguar Cars & Trucks
Tranmission flush 95 deville
Most likely a 4t80 ******, biggest FWD unit GM makes. Only way to drain is by removing pan. That includes replacing gasket, and while you have it off, you might as well replace filter - theyre usually sold together in a kit. Must make sure that all debris from old gasket is clear of pan and case surfaces. Any leftovers can make for a bad seal on new gasket, causing leaks. Consult a parts store or transmission specialist for the proper dexterity and amount of new ****** fluid to fill unit after the new pan and gasket have been installed. Also, before doing this yourself, get prices on all supplies and then compare it to the going rate of your local transmission shop for a fluid change. You may be surprised and save yourself a huge headache and a mess in your garage.
Aug 03, 2012 | Cadillac DeVille Cars & Trucks
Need a replacement gasket for the Cook power blender
Boy, I spent some time on this and - so far as finding an exact replacement on the Internet - I'm stumped.
But I'll tell you what I'd do, in your position.
I'd take the old worn (or split) gasket to Ace Hardware or True Value, and ask someone to match it up for you. Really, a gasket is a gasket. It's just a matter of the size, the thickness, and the "compressability" of the rubber (obviously, you'll want a soft rubber gasket). If you find one, you may want to buy two of them... just in case.
If this doesn't work, then get a square piece of rubber gasket material (Ace, True Value, Home Depot, etc.). You can either cut one yourself (use cups, jars, measuring spoons that are the right diameters to draw your two ring patterns), using an Exacto knife to carefully cut them out.
If you don't want to do this yourself, ask someone who's handy & who has a steady hand to do it for you. You can pay them with a freshly made smoothie.
Mar 03, 2011 | Cook's Essentials Smoothie Maker Work Top...
My 2004 gto has leak water from the driver window so any suggestions
take it to a dealer and ask them to replace your driver's door gasket and the hinges if possible. you may be able to replace the gasket yourself.
Dec 12, 2010 | 2004 Pontiac GTO
How many intake manifolds does a 1998 buick park avenue have? Also is this a difficult job to do? I have heard these cars are notorious for melting there intake manifolds, is there a metal replacment of...
2 upper pellum and lower intake gasket( both are called intake gaskets) I did it. time consuming alittle but if your ave or above with mechanics then you'll save yourself $2000.. the new pelunum and gasket cost $130 and it comes with improved gasket and a replacement pipe the melts also. lower gasket $40? need more help or info email me! Richie
Sep 30, 2009 | 1998 Buick Park Avenue
I have been told that I have a valve cover leak. Will it harm the motor if I continue to drive it? How much does it cost to repai? The model is 2000 Nissan Xterra
You can do the repair yourself. Your valve covers leaking will result in you losing oil because it's not making it's way to the oil pan. You probably won't hurt the engine if you keep the oil level constant, but you can replace the gaskets yourself. It's a bit of a job, but not too bad. You'll proably have to remove the intake manifolds and replace these gaskets before the valve covers. The valve covers are just plastic covers for the valves-one big box. Put new gaskets in place and reinstall the reverse of removal.
Jul 18, 2009 | 2000 Nissan Xterra
Valve adjustment
The EA82 does not use shims. Ticking almost always caused by a failed oil pump to engine block gasket failure. The gasket slowly fails which then allows the oil pump to pump air along with the oil. Replace the "Mickey Mouse" oil pump gasket.
May 30, 2009 | 1992 Subaru Legacy
How replace transmission seal, gasket and filter
If you can pull and replace your trans yourself, you can get your drive axle seals, main seal, filter and gasket for $100.00 or less.
May 24, 2009 | 1989 Toyota Camry
Frigidaire GLTR1670A Front Load Washer Logo
85 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
