Question about Kitchen Ranges
I have a 9 year old whirlpool range and the electonics have locked the oven door. The code shows F5E1. How do I get this door open.
  • 149 Answers
Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction
Posted on Mar 27, 2010
How do I find out what FSE1 or F5E1 means on my oven display
If your oven is by Whirlpool (or from that family), the F5E1 error code indicates that the door lock mechanism is damaged, lock motor isn't working or the sensor can't tell if the door is locked. Did you try to do a self-cleaning cycle on the oven recently? Can you open the oven door? Look at the lock mechanism near the top of the door jamb in the oven and check whether the latch move freely from left to right and back. If the oven door is locked, you open the back panel and try to manually move the lock mechanism to open the door.
Please add a comment with the model of the oven for further assistance. The model number will be on a plaque on the oven frame for most models.
I hope this helps.
Feb 01, 2015 | Exercise & Fitness
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
What is the solution if my oven beeps?
Hello friend, thank you for your inquiry!
I understand that your door is locked and you have error "F5E1" showing on your range. I would perform a reset on your appliance which can be done by flipping the household circuit breaker off for roughly ten minutes. If that does not correct the issue and you continue to receive the error "F5E1" I would contact a professional to come out and repair your appliance because it could be an issue within your UIB (user interface board) or main control panel. Hopefully this helps. -Matt
Sep 15, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
Why does the message F5E1 come up on the oven display after I auto-cleaned the oven. The oven is still locked. MOD: RF 265LXTY3, Serial #RW-1117104-X. I have a manual, but it doesn't tell anythi
The F5E1 message means that the door lock mechanism isn't working. This could be a fault at the lock, the mechanism or the wiring.
First press and hold Cancel to clear the error temporarily. Another code should appear. Press Cancel again to clear the second error. (Some models require unplugging the power cord to reset the code.)
To unlock the door, take a metal wire hanger and bend it. Slide it into the door opening and try to get the lock to move. (The lock is in the middle of the opening.) Then try to open the door. Otherwise, see below to see if you can unlock the door from the back of the unit.
You can check some of the parts by taking off the back panel and attempting to move the lock. Similarly check the motor and the cam that controls the lock. It should take a bit of force to move but not a lot.
I hope this helps.
Jan 08, 2013 | Whirlpool Kitchen Ranges
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool oven gas range is beeping and is displaying F5E1.
This is a problem with the door latch switch. You will need to remove, check for continuity with latch open no continuity closed should have continuity. If the switch has continuity with latch open replace. I have replaced quite a few of these over the years, they usually seem to go during a cleaning or right after the oven was cleaned. Enter your model # at www.appliancehelponline.com for an illustration. The switch is inexpensive and easy to replace.
Mar 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door is locked and won't open
Sorry to hear the "self clean" Gremlins are at it again. Several things have happened, none good. During the cycle at full power for several hours, a circuit on the control board has failed. Various errors are now keeping functions from occurring normally, although sometimes door switches fail causing similar anomalies. At any rate 'self clean' eventually becomes 'self-destruct'. Boards run 150-300$ . Hope info helps- Thanks-ED
Feb 27, 2010 | Kitchen Ranges
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
303 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
