Question about Dell 3100cn Laser Printer
When I print color with my Dell 3100cn the color does not match what I see on the screen. I somehow need to make what prints match the monitor. HELP!
  • cking481 Jan 31, 2010
    When I print to the Dell printer, the color is seriously different than when I print to the HP printer. The HP delivers the color that matches very closely; the Dell is quite different. Somehow, I need to 'calibrate' it so that the document prints the same on both printers.
    Novelist:
  • 157 Answers
In general the color on the screen is never exactly the same as the printer. You will have to play with the colors on the screen and test the output to see if it is what you really want.
Posted on Jan 30, 2010
Dell 3100cn prints the wrong colors
Go to Control panel
Click on: Hardware and Sound
Click on: Devices and Printer
Click on your printer
Click on Adjust printing preferences
Then go to the Maintenance Tab at the top (should be last tab)
Then click Print a test page
You can also Align Ink cartridges from here and clean the Ink Cartridges
If that does not work then update the drivers:
Go to Start
Type in box Device Manager
Click on Device Manager in list
Wait till list populates.
Click on Imaging devices
Right click on the printer
Update the drivers by searching online
Apr 03, 2013 | Dell Laser Printer 3100cn PCL6
Dell 3100cn printer prints individual colors fine. When printing full color picture the paper wraps around the fuser. Tried new fuser - same problem. Any suggestions?
Good old fuser wrap, what a pain. What type of paper are you printing on. Often with full page coverage printing I find that you need to user a heavier bond color printing paper to achieve any sort of good quality and reliability in feeding.
Mar 18, 2011 | Dell 3100cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
I am printing a color doc but everyting is in gray scale. how do i fix that (it is colored on the document page on the screen)
just go on the setting option and see that the option to print the color copy is check mark on it or not
Dec 17, 2009 | Dell 3100cn Laser Printer
Our Dell 3100CN printer blocks out a 1/2" wide line (all colors) print area on the right side. We replaced the printer drum unit and that didn't fix the problem. It was printing fine until we replaced the...
Try the cleaning rod. visit: http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html
for images (under replacing the "cleaning rod pad") for where to find the cleaning rod. You likely don't need to replace the pad, just use the rod (pull out and push in 10X) and try to print again.
Cheers
Oct 22, 2009 | Dell 3100cn Laser Printer
Marks and smugges on the prints made my dell 3100cn color printer
All color printers have a calibration mode.Essentially it makes sure that everything starts and stops at the same time.It should be accessible on the contol panel
Mar 24, 2009 | Dell 3100cn Laser Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Dell 3100cn
I've the same problem with a 3000cn but on the black color. all other colors are great execpt the black one.
Any Ideas someone ?
Apr 02, 2008 | Dell 3100cn Laser Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
87 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
