Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Muffler bolts seem to tight but the muffler itself is loose! how is it suppose to come off the motor? thank you very much!!
    President:
  • 2,220 Answers
We need a model and serial number to provide a quality answer. You can respond below. Lou
Posted on Jan 31, 2010
  • dontbother10
    dontbother10 Jan 31, 2010
    I must be getting tired that was supposed to be a clarification request.
    Go here:
    HusqvarnaUSA.com
    http://www.husqvarna.com/us/homeowner/su...
    Enter the 3 digit model number (no XPs, Es, just the numbers)
    Serial number decode – useful when downloading IPLs and Manuals
    06 1500198
    06 = year produced – 2006 (single digit before 2000)
    15 = week produced - March
    00198 = 198th unit Husky produced that week
    Open the correct IPL and you can probably see all muffler mounting components (Detail F on the 359 listed).
    HTH
    Lou
I have a husqvarna 350 chain saw the muffler bolts come loose almost every time i use it can i use lock tight on the bolt?
you can use loctite but make sure it is a high heat or it will just get hot and break down and leave you in the same boat.
Feb 11, 2013 | Husqvarna Chain Saw 20" Bar
What's your problem? Why would the bolt continue to back out of a brand new CRAFTSMAN MOWER ELECTRIC CLUTCH on my ZTR?
The only thing i can think of is that the woodruff key has fallen out, this would allow the clutch to spin on the crank and loosen the bolt, if the key is there and the clutch bolt is tight it just cannot come loose, is the crank worn, i e is the clutch a loose fit on the crank??
May 21, 2012 | Garden
I have a Craftsman LT 2000. I ran over a dog chain and now the blade is loose. It rattles loudly if I engage the blade. Everything seems intact and tight except the blade itself. Any advice would be...
If the bolt holding the blades on is tight, then you will need to remove the deck and remove the blade to inspect the five pointed star on the bottom of mandrel (that is what sears calls it, other manuf. call it a spindle) . If this is damaged you will need to replace the mandrel. They run a little over sixty dollars.
I hope this is helpful.
Aug 30, 2011 | Garden
Installation of the Lexus ES300 muffler consists of course of the muffler and bolts to attach the muffler to the tail pipe, it also has wax like donut which is inserted into the muffler where the tail...
the bolt goes through the both flanges and the springs go against the last flange and under the nut of the bolt
it is a system that allows movement between the couplings so that the system doesn't crack from fatigue due to engine/ , pipe movement
May 02, 2017 | 2000 Lexus ES 300
Unit makes a rattling noise ,compressor vibrates when it comes on ,i can't tell if fan is loose or compressor is vibrating? i did notice the compressor is loose,is it supposed to be bolted down tight?
Yes, the compressor should be bolted down tight enough to be pressing against the springs beneath it, but not so tight that it completely smashes the springs. If there are no springs beneath the compressor that could also be the cause of the noise problem.
Mar 29, 2010 | Beverage-Air MT17 Refrigerator Commercial
2000 Dodge Durango Problamo
It's definitley not supposed to be loose or wobbly. Take a look at it and see exactly where it's loose, you may be able to tighten it using the bolts on the pulley. Otherwise if the pulley itself is bad you'll have to replace it.
Nov 14, 2009 | 2000 Dodge Durango
Oil leaking from two screws on exhaust model10a902 type 2272 quattro 40 thanks ray
Most likely engine has been tipped on it's side, and the muffler is full of oil. Does it smoke? The oil will eventually burn off anyway, but if anything is able to leak past the mounting bolts, they must be loose. Check that the bolts are tight, and the lock washer is present and not rusted away.
Oct 18, 2009 | Garden
Samsung fully automatic washing machine
HI The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Oct 14, 2008 | Washing Machines
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
96 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
