Question about Canon EOS 40D Digital Camera
Need help with blurry shoots when blown up with my canon 40. I am storing them on large/fine image recording and use a tripod. I am stumped.
    Brigadier General:
  • 11,967 Answers
Does your camera have a shake reduction feature and do you have it on? If so, it's supposed to be off when you use a tripod.
Posted on Jan 30, 2010
Blurry pictures of moving wildlife
check shutter speed, problem to slow, increase aperture if light level permits hand shake can also blur image.If in full auto mode change to manual settings mount camera onto tripod THIS WILL SOLVE HAND SHAKE PROBLEMS the most common cause of blurred images.
Nov 22, 2013 | Canon EF 75-300mm f/4-5.6 IS USM Lens
When I take a picture with my 18-55 on a d3100 I hear and see through my visor that the image moves and a sound like a click, many seconds after taking the picture. It seems like it's still open and closes...
Giving the lens your using and depending on the shooting mode your in. I assume your shooting in a low light situation. The lens you have is not good for low light shooting because the F-stop is only 3.5 at widest, so minimal light gets in so the camera decides what speed to set it at to close the shutter. for example shooting in the school gym or church, the camera speed will be 1/20 second or even up to 1/2 second to get enough lighting into the sensor so the image is properly expose but for you to have a sharp image you will need to shoot on a tripod.
Without tripod and just handheld will create blurry images. I would suggest you bump up the ISO setting to minimum to 3200 or higher that way the camera speed will be higher and reduce handheld shakes that will create blurry images. But remember, increase ISO will increase in image grain.
That is why I suggest you invest into a 17-50mm F2.8 lens for low-lighting or 50mm f1.8 lens.
I hope this helps
Jet
Feb 23, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Shooting in low light with a canon rebel xt
Hello parr_alp,
Please keep in mind that when shooting in low light, you will ALWAYS get some amount of blur when you are hand holding the camera unless you use a flash. The only way to increase your shutter speed is to crank up your ISO setting to 800, 1200, 1600, etc. If there is no tripod handy, brace yourself against a stationary object and remember to keep your elbows tucked down near your body when shooting (no sense in holding up your arms, too).
There is no way to increase the ISO limits of your camera while maintaining quality of your images. And once again, you will ALWAYS get a certain amount of blur when hand holding the camera.
The external flash not firing is an entirely separate issue. This could have to do with your metering, a bad flash, bad connection in the hot shoe, what shooting mode you're in — the possibilities are numerous. The next time your flash doesn't work, write down all the settings of your camera and keep track of them (i.e. shooting mode, metering mode, flash settings, current lighting situations, etc.) You may start to notice a pattern and perhaps we can help you here.
Anyway, happy shooting, and if this response was helpful, please rate it! Thank you!
Jeff
Mar 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I am trying to get clear closeups of teeth (work in a dental office!) and I keep getting blurry pics. We do have a telephoto lens but I have no idea how to use it... Help?!
For the best photos of close-up it is recommended to use a tripod since the Canon A620 has no image stabilization. You can then use the macro setting and set if for the distance you will be shooting from and your photos will be a great clearer and with no blur
Dec 01, 2008 | Canon PowerShot A620 Digital Camera
Autofocus...images often blurry
upper right of camera back side is bracket with 3 dots [---], press and change to center point for accurate focus ... also in tripod shooting, you can set a delay (timer) for 2 seconds to make sure that the camera is still while shooting
Aug 19, 2008 | Olympus EVOLT E-500 Digital Camera
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Fuzzy images
Hey jjbeanwink,
This is a very nice lens, and is unlikely that your blurry images are caused by the lens. The most common cause of blurry pictures is that the shutter speed is set to low. A general rule would be your shutter speed should be at least 1/60th of a second while handholding the camera. The bigger the lens, and the higher the magnification of the subject you are using the faster the shutter speed you should use. If camera shake is the cause of your blurry pictures you could also try using a tripod. Another common cause of blurry images is subject movement, and one solution would also be setting a faster shutter speed. Another solution is using the flash to stop the action instead of the shutter speed. Of course manufacturers do occasionally make a bad product and that is why there are manufacturers’ warranties. If you just purchased this lens you could have an authorized service technician look at the lens and see if there is anything wrong with it. I these suggestions help!
Sincerely,
Allan
Go Ahead. Use Us.
May 12, 2008 | Canon 24-70mm f/2.8 Lens
How to increase brightness in Canon Powersot A620 ?
Are you asking about brightness as viewed on the LCD, or are you asking about increasing brightness on the actual image taken? If it's the image, there are two special modes that you can select on your mode dial. They are "Night Scene", "Night Snaphot", and "Indoor". A description of both, along with your camera's other special settings, may be found here:
http://www.canon.co.jp/imaging/mode/camera/scene-e.html
"Night Scene" can be selected directly from the dial. It's the one showing a person standing under a star. Note that Night Scene should be used with a tripod to reduce the potential for blurriness.
"Night Snapshot" works almost as well, but does not require a tripod. It can be accessed by selecting SCN on the dial, and then pressing right or left with the selection buttons until it shows in the menu. The camera will remember this setting the next time you select SCN. I usually keep my camera always set to this setting so that I merely have to select SCN to use it.
"Indoor" works very well in those large rooms that may produce dark backgrounds when taking photos. It also does not require a tripod. It's accessed the same way as "Night Snapshot" (Select SCN, then right/left until selected). This is another good setting that I like to keep sometimes set in SCN.
Try all three settings, (and don't forget all the others too). Think you'll be impressed.
Feb 23, 2008 | Canon PowerShot A620 Digital Camera
Trying to take pictures in low light conditions inside a theater.
when you use high ISO like 800-1600 it will create big novice on image, and when you using law ISO it will be dark for sure.
so the solution is switch cam to TV mode and put into very law shutter speed and use ISO 200-400,make sure you are connected to tripod or else you will not get fine results with law shutter speed. point is when you use law shutter speed camera will take more light to censor even with law ISO your images will be perfect.
Dec 06, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 40D Digital Camera Logo
52 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
