Question about Bissell 1400 Little Green Pro Canister Steam Vacuum
There is no spray coming out of the machine when I pres trigger.Tried all bissell tips,is there any place to get a prodecure for getting to the pump? Thanks-Andy
  • 17 Answers
Here is what to do
Posted on Feb 09, 2010
I CANT GET MY BISSELL SPOTLIFTER MODEL 1716 TO SPRAY THE SOLUTION.
1) Make sure there is water in the solution tank.
2) Try priming the machine by instructing the consumer to squeeze the trigger
repeatedly for 1 to 2 full minutes. Important: If you cannot
squeeze the trigger all the way in, remove the tank from the back of the
machine and then try squeezing the trigger with the tank removed. There is an
internal valve that could be sticking. By removing the solution tank and squeezing
the trigger, it should break it loose, allowing the trigger to be fully depressed.
3) Make sure the open end of the siphon tube in the solution tank is not pushed into the
side of the tank, covering the end of tube. If it is, push the bend in the
Siphon tube toward the back of the solution tank.
4) Check to see if the siphon tube has become disconnected from the outlet fitting on
the inside of the solution tank. If so, you need to buy a replacement solution tank. Parts
can be found at www.bissell.com
5) Check to see if air comes through the spray tip by repeatedly squeezing the trigger
with solution tank off the unit. If not, spray tip may be clogged. Try and unclog
spray tip with a pin or paper clip.
If still no spray, please check the following:
a) Make sure the solution tank is installed properly.
b) Check to see if black O-ring is present on rear connector to solution tank.
May 28, 2011 | Bissell 1716 Spot Lifter PowerBrush...
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 9500 proheat 2x wont spray liquid to the floor
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghhdg
May 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Biseell little green machine wont squirt water out
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Bissell 7920-E; No spray.
I have a similar problem and `phoned Bissell support. They told me that no spray is either a failed drive belt or a failed pump. I suggest you remove the belt access cover and see if the belt is intact; if so rotate the pump using finger pressure - it should rotate easily with no unusual noises.
If this is all OK, fill the bucket and the mix bottle with warm, clean water. Turn the machine on and with the handle upright press and hold the trigger for about 2 minutes. Hopefully you should see a spray and both the bucket and bottle will reduce in volume. If not you have either a blockage in one of the tubes, the trigger valve needs adjustment or, worst case, the pump has failed.
Hope this helps.
Jun 06, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Power Steamer Pro
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
No spray
Here are 3 common things that causes this problem:
• clogged spray tips
• defective solenoid valve in the base
• defective trigger microswitch in upper handle
Mar 16, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1400 Little Green Pro Canister Steam Vacuum Logo
345 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
