Question about ASUS K8V Deluxe Motherboard
I just disabled my promise controller to get the message fasttrack controller not conected ,then i got message Pri Master Disk : S.M.A.R.T status bad, Backup and replace is it reading the hard drive or could it be not connected in the right spot? Thanks
    President:
  • 1,015 Answers
I just posted a comment to you on the original question you gave. What sounds like happened to me is when you installed the video card you might have loosened or dis-connected a hard drive cable. And if you plugged it back into the wrong spot that would explain why you originally got the "Fastrack error". I think you will just need to verify that the SATA cable is fully plugged in and into the correct SATA port on the motherboard.
Posted on Jan 30, 2010
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
How do I back up my computer when this message appears Pri Master Hard Disk : S.m.a.r.t. command failed Press F2 to resume
restart computer and press delete button and in BIOS menu go to advanced menu set S.M.A.R.T disabled.
Jun 10, 2012 | Sony VAIO PCV-RZ44G PC Desktop
Ai got an old computer and it it work but it show me an error with American Megatrends
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps you
Jan 07, 2012 | Computers & Internet
Asus P5RD-2-UM acpi bios revision 0811. Press del to run setup Press F8 for BBS popup initializing usb controllers..done. 992mb =32 mb shared memory avto detecting pri master ide hard disk pri master...
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
Dec 20, 2010 | ASUS P5RD2-VM Motherboard
Pri Master Hard Disk:S.M.A.R.T. Command Failed
You do not seem to have a smart capable hard drive, disable the setting in the BIOS by pushing F2
Jul 05, 2010 | Computers & Internet
Master hard disk s,m,a.r.t.status bad,backup and replace
A failure message from the SMART system of this nature indicates that a catastrophic hard drive failure could be imminent. Without delay, back up ANY data you want to keep. This error isn't going to go away, and is being reported by the drive controller.
Whilever you can access the drive, move any data you want onto another media (such as DVD or external USB hard drive) because chances are it's not going to work much longer. You need to look at buying a new hard drive as soon as you possibly can, and migrating the data to it.
Files and Settings Transfer Wizard will be able to backup your data to another media.
Jun 02, 2008 | Computers & Internet
When booting up my pc...message comes back - "Pri Master Hard Disk: S.M.A.R.T command failed"
Go to the bios screen at startup and disable HDD smart .
typically this option is found under Advanced chipset menu. you enter setup by pressing F1, the 'delete' key or what ever key it says when you first boot the sytem. Go to Hard Disk Management or what ever they call on you cmos/bios/setup and shut it off. This will allow you to transfer what you need to back up.
Apr 23, 2008 | Computers & Internet
Repair
i think this is a os problem or hardisk problem change check hard disk
Oct 23, 2007 | Acer Aspire 5100 Notebook
ASUS K8V Deluxe Motherboard Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
