Question about NetGear Computers & Internet
Frequent interruption to wireless users:
Netgear WGT624 Router and (3) wireless users: Router signal is frequently interrupted to wireless users. If I unplug and plug back in the router, the signal is restored. Do I have a bad router?
    Scholar:
  • 94 Answers
RF interference is the most common reason why WiFi will drop signal from time to time. First – make sure your wireless router is not next to a source that can cause interruption. I have mine on a shelf about 5 feet off the floor. Also make sure that your wireless home phone is not right next to it. Home phones can cause issues with signal as well.
Keep me posted
Posted on Jan 30, 2010
HOW TO RESET THE ROUTER
You can reset your Netgear router/wireless WGT624 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless WGT624 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Feb 06, 2012 | NetGear : WGT624 108 Mbps Wireless...
During watching movies streaming from netflix/ PS3 to hdtv there is frequent interruptions. "Retrieving" for 1 to 3 min. How do I fix this issue?
if you are on a wireless connection it will ocur when your connection qullity changes go cat-5 cable if you alredy have this setup reset router and modem
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
Netgear wgt624 v3 problem,cannot go to any sites
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 27, 2010 | NetGear WGT624 Wireless Router
I'm having a problem with my NETGEAR WGT624v3 router. I have it connected through a SPEEDSTREAM 4200 modem and have experienced no problem with the internet connection. However, after approx. 3 to 4 hours...
yes set the speedstream modem to log in. it is uner advanced, usually 192.168.0.1 address. It is most likely set to "bridged" mode and using the router to login. set login to ppoe on speedstream on one p.c. only 1st. with login ang password filled in and "smart keep alive" on.
Oct 31, 2009 | NetGear WGT624 Wireless Router
Extremely inconsistent connection to router (Net Gear) & Internet
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Netgear router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Netgear router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router:Netgear suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router:
Having default wireless settings on the Netgear router may cause conflict with other Netgear routers within your network range.Netgear suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 18, 2009 | Computers & Internet
WGT624 v3 transmits no wireless signal.
You have to set up your router again. The id will be "admin" the password "password".
See manual" http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
Feb 19, 2009 | NetGear WGT624 Wireless Router
Need to add a new laptop onto my wireless router wgt624 v.3
By default, Netgear uses admin and password. The username is always admin, the password is the only thing that changes. If it's not that, there is always the reset button in the back of the unit.
Carl
Dec 30, 2008 | NetGear WGT624 Wireless Router
Wireless internet connection
Fog will not affect radio signals. Please go to the following website and follow the instructions.
http://kbserver.netgear.com/kb_web_files/n101676.asp
Oct 30, 2008 | NetGear WGT624 Wireless Router
Computers & Internet Logo
452 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
