I have the ethernet cable plugged into my modem. The set up works ok until I have to activate the "link code" and because I had to plug the cable into the modem where the internet cable usually goes, I cannot get the link to go through. I do not have a router. Do you know if there is a port on the back of a Dell computer 3100/E310 where I can plug the ethernet cable in directly and not have to use the modem port? Is there anything you can suggest? Thanks.
  • hugh2u Jan 30, 2010
    Perhaps I should get a simple "wired" router--can you suggest a compatible one just to use with the Roku box?
  • 3,940 Answers
  • 1,596 Answers
If your DELL Computer is a Newer Model it Should Have An Ethernet Cable input if Not You can Purchase a Ethernet Card And Install it Fairly Simply. If it Is Required that you use an Ethernet Cable this your Only Solution
Posted on Jan 30, 2010
How to set up D-Link router
Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem.
Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet.
Remove the power cord from your modem and wait 10 seconds before plugging it back in. This will reinitialize your modem and force it to establish a connection to the D-Link router. Your router will immediately begin distributing a wireless network with the "D-Link" network name.
Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser. Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field. Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network. Click "Apply" to save the changes to the router's settings.
Feb 08, 2012 | D-Link Computers & Internet
I am trying to access the internet wirelessly from a lap top through a D-Link DI-624 I went throught the steps 1. plugged up the router 2. unplugged the DSL box 3. plugged up the ethernet cable to the DSl...
Unplug the power cables from both your DSL modem and D-Link router.
Verify the Ethernet cable is plugged into both your DSL modem and the D-Link router.
Plug the DSL modem power cable back in and wait for the self-test to finish.
Plug the D-Link router power cable back in and wait for the self-test to finish.
Plug your laptop into the D-Link router using an Ethernet cable.
Can you access the D-Link configuration page now?
Check to see if your computer is getting an IP address from the D-Link router.
Here's how to do that, assuming you're using Windows.
Hold down the Windows key on your keyboard then press the letter R.
In the Run dialog box type 'cmd' (without the apostrophes).
Click OK.
In the command prompt window type 'ipconfig /all' (without the apostrophes).
Press Enter.
Look for the line that reads 'Ethernet adapter Local Area Connection'.
Verify that 'Dhcp Enabled' is set to 'Yes".
Mar 14, 2011 | Computers & Internet
I want to add one user name of my pacific account
Please list some more detail so I can help.
1. I am assuming you are using your router to connect to the internet through Pacific.net. do you have the correct username and password for your pacific account?
2. What is the name and model of the router?
3. have you changed the default lan ip settings?
Jan 05, 2011 | Computers & Internet
Ethernet cable 'splitter': Works on AT@T 'light' modem but not on cable modem. Are splitters speed sensitive
Splitters that work on telephone modems are not designed to work on cable modems. If you are trying to allow more than one computer to access the Internet, you need a broadband router.
You can find them on eBay and at stores for under $30. The primary difference between them is the number of "ports". A port is simply a place to plug in your PC. The more ports, the more PCs you can plug in.
Here's how you set a router up.
1. Plug a short Ethernet cable into the Ethernet "out" port on your cable modem.
2. Plug the other end into the "Uplink" or "WAN" port (will be labeled one or the other.
3. Plug an Ethernet cable into the LAN card on your PC and the other end into one of the open Ethernet ports on the router.
4. Reboot each PC.
You should be good to go!
Oct 25, 2009 | Linksys computers10: EtherFast Cable / DSL...
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
My router doesnt work now that I have a new modem. I have Comcast internet and the Blitzz BWA611 router
Have you restarted the devices in order?
  1. Unplug the Ethernet cables from modem to router and router to computer.
  2. Restart the modem and wait until all lights are on
  3. Restart the router and wait until all lights are on
  4. Plug in an Ethernet cable from modem (first) to router (WAN or Internet port, second).
  5. Plug in an Ethernet cable from the router (first, LAN port) to your computer (second).
  6. Check the settings of the router - Make sure it is set to DHCP.
If you have any more questions or this description is not clear to you, just come back here and leave a comment - I'm happy to help.
May 19, 2009 | Blitzz Technology (BWA611) Router
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
Automatic installation failure
unless you were switching from DSL to cable Broadband, there usually wouldnt be much reason to rerun the software just because you got a new computer. when you ran the software the first time on the other computer, it was the router you were setting up, not the computer.
if the new computer is not getting internet when hooked to the router, try this.
1.turn off computer and unplug electricity from router and cable modem.
2. connect all ethernet cable to the right location. ethernet from modem to router goes in the non-numbered port, ethernet from your computer to router goes in numbered port.
3. plug in cable modem electricity first, wait for all its lights to come on like normal.(this part is important). the ethernet light on the modem (it might be labeled ethernet, link, pc link, or something similar) will not be lit, this is normal until you get to the next step
4. plug in the router electricity, give the router 2-3 minutes to get connected to the modem.
5. start up the computer, wait for everything to fully load and check internet again.
hope this helps.
Mar 21, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Desktop and two laptops won't work with modem & router now
Probably you used the wrong type of ethernet cable, a crossover one. Try another Ethernet cable but this time a straight one.
Mar 11, 2009 | Westell Wirespeed ProLine 6100 Router...
Ethernet cable port does not worked only the usb port worked
Have you tried changing the lan settings, or better still use the disc that came with modem and it will auto install modem and configure settings.
Jul 27, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
