Question about Elna 2007 Mechanical Sewing Machine
Elna 1600 i have an elna 1600 with the flat lying bobbin casing. i have used it many times but for some reason the bobbin casing (black plastic) wont turn and hence the thread can no be picked up? can you help?
    New Friend:
  • 185 Answers
On a 1600 the bobbing case should not turn. the metal around it should. It should remain stationary.
The part thet turns is called the hook. Is the hook spinning. Is a new needle in the machine? That is where I would start.
Posted on Feb 19, 2008
Elna Lotus bobbin wont insert
YOu have got to get the bobbin case out. Turn the flywheel with great strength to make it bring the needle up. Take the foot off and the needle out.
Dec 01, 2017 | Elna Sewing Machines
What are the correct settings for basteing on an elna excellence 730
Here's a manual for your machine:
ELNA eXcellence 730 Instruction Manual
If your machine does not have a "basting" stitch selection, you make your own basting stitch by:
* Setting the stitch length to the maximum
* Loosen the upper tension so the bobbin thread lies flat under the fabric
Then to gather or remove the basting stitch, it is easy to pull on the bobbin thread.
Mar 12, 2017 | Elna Sewing Machines
How can I reinsert bobbin race back into my elna su 68?
Hey I can help you with this, its a long detailed explanation though. Have you removed the bobbin holden, ie,undone two small screws and lifted out the silver bobbin case, leaving a black round thing? This black bit is the lower ring guard, you have probably undone this to remove a thread caught in the edge of the bobbin case or umderneath. Elna manuals never detailed cleaning here but it is simple enough and needs doing from time to time, i have seen big wads of felted threads and lint under guard rings when pulling apart machines. This video shows how to line up the lower guard ring, the outer casing and the bobbin case.
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
I always turn the flywheel until the opening of the lower casing is facing forward, then look at the black lower guard ring and turn it until the cut out bit is facing the front. Now look a the bobbin case, it has a couple of silver Beaks and these need to fit in between the stoppers on the outer case. You will know if lined up right as it just fits straight in, wiggle a bit left or right until its lined up. Those two silver screws have to marry up with the two holes in the lower guard ring.
Once aligned , tighten up the two screws until firm. There is a dark coloured screw too, leave it alone.
Hope,is helps, once youve done this a couple of times, its easy.
Sep 04, 2014 | Elna Sewing Machines
Spoolcase assembly
Do I understand right, you unscrewed two screws on the bobbin case holder and lifted it out? Underneath is a black plastic ring (inner guard ring) which sits inside the lower guard metal outer. I guess you undid the bobbincase to clear under it, I have seen machines with a lump of lint under turned into felt from being left so long. While its out, clean the underside and under the inner guard ring with your little brush, chech the bobbin case holder side too, there is a little groove on the side and sometimes tiny bits of thread will be caught in it. The trick is to turn the flywheel until the lower guard cutout open bit is facing 6 on a clock dial, ie closest to you. Now look at the inner guard ring, it has a flat edge cut off, turn it so the cut out faces about 7 on the clock and centred in the outer guard. Now you need to insert the bobbin case, it has a piece with two "beaks" on it, this is the front and these beaks need to sit between two metal parts in front of the outer ring which holds the bobbin case firmly. Put the front part in place and the whole case will fit in perfectly, just give it a little wiggle if it doesnt quite line up. Tighten the two shinny silver screws to fasten in place. There is a little black screw too but dont touch this, its a fine tension adjustment. Hope this assists you, if not post again andI will try to find a photo of the assembly.
May 20, 2013 | Elna Heirloom Edition 6005
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
May 06, 2011 | Elna 2005 Mechanical Sewing Machine
Bobbin case making noises and bobbin thread keeps breaking the material also pukkers up underneath
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, it looks very similar to this Elna so I'm thinking its the same design bobbin and race. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room).
PLEASE NOTE: If you've never pulled this bobbin area apart before, good idea to snap pics with your digital camera as you go to refer to and for reference next time!!
This uncovers the bobbin holder area, you'll see there is a black plastic holder which your bobbin goes into which has the tension device on the side and this then sits inside an outer metal casing which is the hook race. The bobbin holder is held there by a magnet underneath it and sits up against another little stopper. Look at the bobbin case and the stopper, there should be two red marks that must line up. Are they???
If the answer is no, then you need to remove the bobbin case, clean out any lint and fluff using your little brush that came with the machine, and you may also have pieces of thread caught in here too. Once clean, place the bobbin case back into the outer surround, under the other piece and lining up the two red marks. This is where photos are so helpful.
Now replace the needle plate and screws, pressure foot, pop in a new needle and thread everything up again.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've pierced it with the needle several times.
I hope that this helps you out, good luck with your machine.tally_girl_3.jpg
Mar 07, 2011 | Elna Xplore 8600 Computerized Sewing...
The thread seems to be getting caught under the plate on something.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've damaged it badly.
tally_girl_0.jpg I hope that this helps you out, good luck with your machine.
Feb 17, 2011 | Elna 7200 Computerized Sewing Machine
Needle hits the white plastic where the bobbin case sits.
It may be as simple as you didnt get the needle pushed all the way up in the needle bar. Get new package of needles and try a new needle and make *sure* it goes up as far as you can push it. the reason I suggest a new pkg of needles is if one is bad in the pkg, they are probably all bad. If that doesnt fix it then the needle bar timing/height is off and need to be repaired/adjusted by a tech.
May 05, 2010 | Elna 7200 Computerized Sewing Machine
Elna 7000 computerized sewing machine
just wonted to see how much these elna 7000 are running now i have one but i just wonted to see what its worth now
Oct 20, 2007 | Sewing Machines
Elna 2007 Mechanical Sewing Machine Logo
466 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
